Tip & How-To about Office Equipment & Supplies
How to SAVE money using LESS ink when printing with your printer. In a few clicks.
The first thing I always recommend to anyone printing is to turn the default print settings of the printer down to draft mode black and white. Now you can leave it to color if you know you are going to need color often. If you print a lot of things just for the simple fact of needing it to read or see. Then chances are you don't the quality to be the best or even close to that. Draft quality is a great way to use less ink. By turning it on as the default you will be saving money with every print, and at anytime you go to print you can just change the settings of that specific print and it won't affect your default settings. So here we go, I will show you the easy steps to changing your default printer settings to draft quality.
Step 1: Click Start > Control Panel
Step 2: Now open Printers And Faxes
Step 3: Right-Click on the printer you use/want to change the settings on. Click Printing Preferences...
Step 4: Click on the Paper/Quality tab at the top. Then click the Black & White and Draft "radio button". Once you have done that click the Apply button. Then click OK. That is it your all done. Enjoy the savings. Depending on how much you print you may or may not notice this. But it is a definite way to save on ink consumption/cost.
Thanks again and enjoy the tip!
-LeeTheDeuce
How do I set my printer to automatically print in draft mode and just black ink without having to manually select these options each time I print?
Wow Pamela! You ask your question well. Good Job! Print options such as that can not be set at the printer. Changing the settings inside the application is not permanent. Follow HPs instructions here for default settings:
Changing Print Settings in Windows7
Dec 27, 2014 | HP ENVY 5530 E-ALL-IN-ONE PRINTER 1200X600...
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
How can I get my HP 6500a plus printer to PERMANENTLY default to black printing? I am needlessly using too much color and the default setting is only for a single document.
Hi
Go to right click at the printer icon on your computer and choose printer properties or printing preferences and from there choose the color setting to print in black alone. Regards
Jun 23, 2011 | HP Officejet 6500 Wireless All-in-One...
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head thing pushed all the way back away from the label. Any suggestions as to what I can do. this doesn't always happen, so is it a bad ribbon?
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
HP Deskjet, Set to Black & White; but still prints with color!
Bronze, hopefully this is a logical issue: Assuming you're on WinXP > Go to Start>Control Panels>Printers (and faxes).
Find the printer in question in the list (maybe there's only one or 2 listed) and 'Right-click' on the icon > go down to "Printing Preferences" (about second/third down the list).
In here you will be able to set the printers default settings. I'm not 100% familiar with HPs printing dialog, but there maybe a setting there for either 'Black & White' and 'Grayscale' (albeit it should be greyscale, anyway...) if you choose black and white your printing will not have any mid-tone, so if there's a choise, choose 'Grayscale'.
You can set other features here which will become the new default each time you go to print something - personally I set to 'Draft' or 'Fast Draft' mode by default, that way when I just print out rubbish, I am saving "lots" of ink and if I want something in good quality, I change it at time of printing.
Now, there are some programs and files that "remember" you last print settings, so if you've used a colour print setting previously, that file may still pring in colour, even though the new defaults are mono (black & white). So, print using the new defaults and save the file when finished. It's unlikely the case with OpenOffice, but, I don't know. We'll tackle that as we get to it.
So, if that has not cured the problem, please let me know.
**.The best way to acknowledge contribution is to rate it's relevance.**
Feb 05, 2009 | HP Deskjet 3845 InkJet Printer
2,243 people viewed this tip
jasbo
jasbo
