Tip & How-To about Washing Machines
Washer will not drain door remains locked
Typical problem for front load washer is that it stops when it comes to a rinse or spin cycle.there is something blocking the drain pump.in order to drain all the water out of the washer the best way is to use a wet dry shop vac.
attach the vaccum to the end of the drain hose and remove all the water.
once the water is removed the door should unlock.then you can access the drain pump from either the front or rear panel depending on the model you have.some models will have a access panel on the front to check to drain pump however if you do not see anything in the pump.
then the obstruction is in the part of the drain hose that leads from the bottom of the tub into the drain pump.if there is no obstruction found then you need to check the wiring and make sure it is securely attach.
last thing when all else fails replace the drain pump.
Washing Machines Logo
Changed the door lock switch to new one and it still won't spin!
typical problem for front load washer is that it stops when it comes to a rinse or spin cycle.there is something blocking the drain pump.in order to drain all the water out of the washer the best way is to use a wet dry shop vac.
Feb 09, 2011 | Frigidaire GLTF2940ES Front Load Washer
will not spin or drain
Feb 04, 2011 | Frigidaire ATF6000ES Front Load Washer
Door will not open
Feb 04, 2011 | AEG Lavamat 88840 Front Load Washer
what is the code E10?
The error codes is a typical error code not real specific
all the sudden our frigidaire front load washer will not spin, what should I do
last thing when all else fails replace the drain pump.There times the door lock mechanism has failed
Jan 13, 2011 | Frigidaire ATF6000ES Front Load Washer
141 people viewed this tip
Top Washing Machines Experts
