Tip & How-To about Audio Players & Recorders
Choosing Bookshelf Speakers
If you are shopping for a quality pair of stereo speakers for music listening not only should you trust your ears but have a look at the individual components that makeup the speaker. The cabinet of the speaker should always be solid, knock on it with your knuckles and see how it resonates the sound. Preferable it will sound dead and solid; we want the drivers moving not the cabinet!
The tweeter: The tweeter is responsible for the upper range and should be made from a rigid yet light material that does not deform when moving quickly, aluminum, titanium and ceramic are excellent. Paper, silk, cloth and plastic are not good for replicating notes in this range.
The woofer, much like the tweeter the woofer must be made from a rigid light material. Yet the woofer reacts differently since it produces a lower frequency range. Paper aka pulp fiber and other fiber composites work very well, as does aluminum and to a lesser extent plastic.
bluetooth & sound
Generally, connecting phones via bluetooth to a laptop just allows for file transfer between the two devices. It is not to input sound from the phone through the speakers of the laptop. You would need a bluetooth audio device for that such as bluetooth speakers or headphones
Jan 28, 2014 | Dell Vostro Computers & Internet
how do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
What stereo amp to be used with jamo s606 speakers (2.0)?
For PC music ( I suppose mainly mp3) you don't need any extra-quality amp, any older Yamaha stereo amp will do. I don't know which of them are available in stores near you, but if you write some model numbers I can check their specs and advise more.
If your PC has spdif output (coax or optical) go for amp which has digital input available.
Dec 27, 2009 | Jamo S606 Main / Stereo Speaker
my bluetooth pairs but won't connect
Hello krissylucas,
Erase the Bluetooth Headset's name from the bluetooth pair devices list on the phone .. and reset the bluetooth headset then try to connect again
Thank you for using FixYa.
Apr 09, 2009 | Eforcity Motorola Bluetooth Headset H500...
want to buy YAMAHA RXZ11 receiver but where to get yamaha recomen
The Yamaha RXZ-11 does not come with any set of speakers. Infact there are no "recommended 11.2ch speaker kits". You are advised to purchase top quality Yamaha speakers. Better yet, build your own 11.2 kit. Its not too hard (internet helps) and its tremendously fun!
Jan 16, 2009 | Yamaha RX-Z11 11.2 Channels Receiver
1,581 people viewed this tip
 Grubhead
Grubhead
