Tip & How-To about Televison & Video
How to Calibrate your plasma panel for less heat dissipation
First you need to take the back off the tv....i know...lol..lots of screws.
try to pile all screws by size.
Now that you have the back off, in the power supply of the unit find
the Vs and Va voltage lines...connect a voltmeter to the Vs line.
on the panel there's a sticker with the factory voltage settings...try to bring
the Vs 10 volts less than what the factory adjusted it to. do the same for the Va voltage line.
The reason for that is that it will deliver less heat on the panel, and it'll
extend the life of your plasma tv.
Thats because what brakes them down is heat.
Televison & Video Logo
Need to know TV Stand Screw sizes
To know more about this, you have to download the repair manual to this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 03, 2014 | Toshiba 47TL515U 47 3D LCD TV
TV Stand Screws
If you still have the manual or know the manufacturer you might want to try giving them a call. They'll know what size screw was used on that model tv stand. Otherwise, measure the insides of the holes and go to a hardware store; they should be able to help you find the right one. Just make sure they are not too long. Screws are pretty cheap, so I'd suggest buying one of a couple different sizes to try out. They should fit snugly in the hole, but should not split the wood/plastic. You'll want to get four of the same size washers and nuts as well once you know what kind of screw you need. That way they won't loosen. :)
May 18, 2012 | Emerson LC320EMXF 32 in. LCD TV
Samsung Un55d6050 TV stand screws
lol go to eBay or shopjimmy.com or your hardware store
Jan 02, 2012 | Samsung Un55d6050 TV
What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
Polaroid TV
You are correct. Polaroid does not make the screws available. You will have to obtain locally, per Polaroid.
Mar 05, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
421 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
