Tip & How-To about Computers & Internet
How to make XP drivers work with Windows 7
I see that many, many people have problems making their "Old" XP Drivers work under windows 7. Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop.
You should have a simple
.exe file sitting on your desktop to install the drivers, as normal for XP.
Right click the .exe file and select "Properties".
Then select the tab called "Compatibility"
Now check the box next to "Run this program in compatibility mode for""
Ensure "Windows XP Service Pack 2" is highlighted.
Now apply the settings and run the installer.
This should work for most drivers, but not all.
SOME DRIVERS MAY CAUSE THE OPERATING SYSTEM TO BECOME UNSTABLE. I HIGHLY RECOMMEND YOU MAKE A SYSTEM RESTORE BEFORE EACH ATTEMPT OF INSTALLING A DRIVER.
Computers & Internet Logo
I can't install compaq ij650 for windowa vista.How to solve it?
I see that many, many people have problems making their "Old" XP Drivers work under windows 7. Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all. make sure you install and run all.any programs as Administrator.
Jun 15, 2010 | Compaq Inkjet IJ650 Printer
i recently aquired a new computer running windows 7 and it does not cover my lexmark x1170.how do i get drivers to make it work on my new computer,please.Regards,John McGregor.australia
I see that many, many people have problems making their "Old" XP Drivers work under windows 7. Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all BUT I don't hold out much hope Win 7 is brain dead with regard to "Older" well it thinks so anyway, things, pre 1009 doesn't exist to Win 7.
Mar 02, 2010 | Office Equipment & Supplies
where do i get a windows 7 driver for this usb modem plse
You cannot, the best you can do, is... I see that many, many people have problems making their "Old" XP Drivers work under windows 7. Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all
Mar 02, 2010 | D-Link AirPlus G DWL-G122 (DHDWLG122)...
I can't get it to load with windows 7
I see that many, many people have problems making their "Old" XP Programs & or Drivers work under windows 7. Here is how to Install them so they work. Download your XP program, driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most programs & drivers, but not all
Feb 17, 2010 | Broderbund American Greetings Creatacard...
296 people viewed this tip
David Payne
David Payne
