Tip & How-To about Computers & Internet
How to configure the wireless connection ?
Configuring the Wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
Computers & Internet Logo
I want to activate wifi on my laptop Model: HP COMPAQ HSTNN-A25C. Please advise the process.
The wifi switch will be in one of the following places. It may have a wifi symbol which will look like radio waves. I hope this helps.
  1. Check the front edge of the laptop for a switch that goes from left to right. The light will normally go from Orange to Blue
  2. check the side edges for the wifi switch
  3. Look at the top of the Keyboard above the number keys to the right. you may find a button there.
  4. Or you can manually turn on your wifi.Click the "Start" button, and click "Control Panel." Click "Network and Internet." Click "Change adapter settings." Right-click on "Wireless Network Connection," and select "Enable" from the menu.
  5. Once you see the wifi symbol at the bottom right of the Laptop screen (near the date/time) click on it and choose your wireless network.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/laura_08254539050d64db
Jul 29, 2016 | HP Computers & Internet
wireless card does not connect to Linksys router, all other computers have no issues. I have a Toshiba M55-S331 with Intell Pro 2200 BG wireless card
Check the Following
Windows XP
2.Find and double-click “Network Connections” to open up the list ofconnections that your 3. computer uses to connect to the internet.
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field onpaper, and store it in a safe place. THIS IS YOUR WEP KEY, it will beneeded later on.
Jan 24, 2010 | Intel PRO/Wireless 2200BG 802.11g/b
my dlink 524 wirrless G won't let me setup a password for security. I reset and go through the setup process. It seems to go fine until It asks me for my password that I thought was setup. It fails to register my password. So I keep reseting it. I may have to let others access my wireless service. Does anyone have a solution.
Check the Following
Windows XP
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
Jan 22, 2010 | D-Link AirPlus DI-524 Wireless Router
i dont have a program wifi for net
I love to help you but you have not specified the Computer details is it Laptop or Desktop but the following steps may help you solving the issue
First Check the following
Windows XP
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
Jan 21, 2010 | Computers & Internet
setting up wireless connection on aceracer, aspire sa90- wireless connection
Check the Following
Windows XP
* Push “OK”
# Click “OK”
# Click “Wireless”
For WEP:
* Click “Wireless”
* Click “Generate”
Jan 18, 2010 | Zonet Fast Ethernet Adapter Realtek 8139D...
637 people viewed this tip
David Payne
David Payne
