Tip & How-To about Cell Phones
How to Check main causes of Hissing Noise on phone line ?
The main causes of Hissing Noise on phone line
* Weather:
Precipitation can leak into phone lines and cause disruptions. Lightning, even at a distance, can damage the connection.
Checked the connections the cable and the Sockets
If you have the Test socket or the First Socket where the Telephone is is entering .. check the Connections there
* Electrical interference:
Check the Power lines,
Check radio or television transmitters, transformers and other electronic devices may causing noise on the phone line.
* Other phone devices:
Check for the Connection to the FAX check by unpluging the FAX Machine or answering machines,
Disconnect the other phones and line splitters --
Disconnect the Splitters or devices that allow two phones to fit on one phone jack -- can cause phone line noise.
* DSL services:
The high-frequency signals coming from DSL (digital subscriber line) devices sharing the phone line can create problems for other technology connected to the line.
***Note : high-frequency signals coming from DSL helps for FAST Internet Connection speed which sometime cause the problem to the Phone or Voice signals for this need to contact to ISP to check the Voice margin .. that may effect your internet Speed
IF the above wont work..
You can try keeping the device near Heater .. it could be the Moisture which might causing this issue
or
Show the Device to the Service provider to repair it
Cell Phones Logo
constant static and noise on the cordless, have not had this problem with other phones in the same location. I have tried the frequency scan- no difference. The noise is so bad the cordless cannot be used.
* Weather:
* DSL services:
or
Jan 22, 2010 | GE Telephone pr521w
I dropped my phone in a little kiddie pool.. took it out and dried it out in the sun.. it worked fine after that for the first day... but then the next day there is an annoying "interferance" noise on the line.. it is worse on the receiving end of the call.. everything else on the phone is fine.. it's just this annoying noise on the phone line.. any thing I can do ???? thanks.
is question has become synonymous with the reliability of a certain cell phone provider, but problems hearing people on the other end of the phone aren't limited to cell phones. Static, hissing, echoes and other noises coming from a phone line can cause equally frustrating problems for people chatting on landline phones.
People who still connect to the Internet using a dial-up connection also may feel the effects of phone line noise, which can interfere with their online surfing. Some modems are so sensitive that even the tiny beep caused by call waiting can terminate an Internet session.
Several things could be causing your phone line noise.­ As the frequently asked questions section of any telephone or Internet provider's Web site will attest, unwanted sounds on your phone line pose a common problem. Thankfully, clearing phone line noise on your landline isn't hard.
As you might guess, the first step in clearing phone line noise is to pinpoint the culprit. Faulty house wiring, long cables or the phone line itself could be indirectly disrupting your conversations. Other culprits include the following:
  • Weather: Precipitation can leak into phone lines and cause disruptions. Lightning, even at a distance, can damage the connection.
  • Electrical interference: Power lines, radio or television transmitters, transformers and other electronic devices may cause noise on the phone line.
  • Other phone devices: Fax or answering machines, other phones and line splitters -- devices that allow two phones to fit on one phone jack -- can cause phone line noise.
  • DSLservices: The high-frequency signals coming from DSL (digital subscriber line) devices sharing the phone line can create problems for other technology connected to the line.
A good rule of thumb is that if the noise only happens occasionally, then weather is to blame. If it's a constant annoyance, then it's probably another offender. Learn what steps you can take to find and stop the annoying noise interrupting your phone conversations on the next page.
Jul 28, 2008 | Cell Phones
where are the vacuum lines on a dodge stratus located i have a vacuum leak which causes my car to turn off
they will be coming of the intake manifold thats were the major lines are that would cause that problem, but you should also hear a loud hissing noise if you do try to track it, good luck.
Oct 31, 2009 | 2004 Dodge Stratus
Hissing noise from Ionic Breeze
The hissing noise is caused by the 5000-volt grid wires arcing. If you look inside the unit closely in the dark, you'll see blue electrical arcs -- these generate the hiss.
The arcing is caused by deteriorating grid wires. If you've cleaned it as well as you can, and it still hisses, it won't be long before it fails.
With Sharper Image out of business, don't know if there is still a repair service for these units.
Charlie
Aug 28, 2009 | Sharper Image Ionic Breeze 3.0 Air...
what would cause ice crystals to form on propane line
Bad hose, bad tank, or seals are gone. Recommenend buying a new tank and new hose. The Ice is from the propane freezing and the hissing noise is a leak from somewhere. Better to replace tank and hose and try again. You do not want to take a chance with propane
Apr 11, 2009 | Weber Genesis Silver B Grill
414 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
