Tip & How-To about Computers & Internet
How to fully protect your PC ?
Ok, First thing you should do is that you must have an anti-virus for you to be aware of it. Second, you may put a deepfreeze application for your computer to be stable (The Harddisk itself) the program may not be corrupted. Third, always be a good observer of your PC when somethings gonna wrong don't be bothered there's a lot of way of solving it. Fourth, always clean your PC environment the sorroundings of your area. And last you have to Clean the inside of your system unit.
TIPS in some memory problems:
- in case of computer beeping a long beep, pull out your memory then clean it with an eraser. Then try to put it again.
- in case of memory dump, please replace it with another one.
Computers & Internet Logo
i am not able to format the pen drive transcend
If you are not able to format pen drive,then you may have a different virus infection related issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
You should always run anti-virus software. There are several very good, free, anti-virus products available. One good source to read editor and user reviews, and safely download anti-virus software, is http://download.cnet.com -- search for free antivirus software. In addition to the reviews, you can see how many people are downloading the software, which is another good indicator of how popular it is.
I have used AVG Free ( http://download.cnet.com/avg-anti-virus-free/3000-2239_4-10320142.html ) , and Avast Free ( http://download.cnet.com/avast-free-antivirus/3000-2239_4-10019223.htm l ). Both are very good, and completely free. At present I am using Avast on all of my home computers.
I have heard good things about Avira AntiVir Free ( http://download.cnet.com/Avira-AntiVir-Personal-Free-Antivirus/3000-22 39_4-10322935.html ), and it has good ratings, but I have not personally tried it.
In addition to Avast or one of the other free anti-virus software packages, I also run Ad-Aware ( http://download.cnet.com/ad-aware-free-internet/3000-8022_4-10045910.h tml ). Ad-Aware is a free anti-malware, anti-spyware package.
Aug 03, 2011 | Computers & Internet
my board is dell made model D865 with 2.6 GHZ processor but my board is not working properly its very slow speed for installing any operating program
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
Jul 29, 2011 | Dell Computers & Internet
To a Hp System ( pentium 4 ) i put a pen drive. Cpu detects and try to install by itself during the process cpu gets Stucked
Just do the following steps and your issue will be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 07, 2011 | Computers & Internet
When I turn it on it it goes to microsoft window xp screen then to a blue screen for about a secondthen to the acer empowering people screen. Then it goes to a screen sorry for the inconveince gives me options to start with safe mode, safe mode with networking, safe mode with command prompt or to start windows normally. I have tried all of them it does the same thing all over again. What do I need to do Please help!!
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications.
right click on each application and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
May 09, 2011 | Acer Aspire One PC Notebook
Anti Virus
Here is what I would do.
First I would start off by downloading the free trial of ESET NOD32 Anti-Virus. Afterward I would scan my system (In-Depth Scan) with the free trial of NOD32 (It doesn't use a lot of system resources). Next I would download the free version of Ad-Aware 2008. After the anti-virus scan finished I would scan my system with Ad-Aware (Full Scan). Next I would download and install Spybot Search & Destroy. After Ad-Aware finishes scanning I would start a scan with Spybot. Next I would download and install AVG Anti-Rootkit Free. After Spybot finishes scanning I would run an in-depth search on all hard-drives with the use of AVG Anti-Rootkit Free.
If that doesn't whack it, fighting this thing might not be worth it. Reinstall the windows operating system after you back up any files which you absolutely HAVE to keep.
Feb 02, 2009 | Computers & Internet
190 people viewed this tip
David Payne
David Payne
