Tip & How-To about Televison & Video
RCA Pro Scan PS52650 fix and price (no power)
No power and won't turn on. I had some indications with TV occasionally going on and off and tricking it with remote (by holding power button for longer periods of time) to turn it back on.
Unplugging
it and leaving it over night then plugging it back in heard three clicks at the back and nothing after that. Doesn't start.
Finally took it to the repair shop and it's power board and it will cost in a range of $300 CAD.
Hopefully this will help some of you guys.
Televison & Video Logo
need code to program audiosonic universal remote to dick smith tv
Give this a go
1 turn on the tv you want to program to work with the remote control. hold the remote in a straight line in front of your tv at a distance of less than 1 metre.
2 press and hold down the remote device mode button (tv) and the (power) button at the same time until the red light indicator lights constantly.
3 press the power button
4 the (tv) button will blink continuously in red meaning that the remote is searching for the code of your tv.
5 when the remote finds your tv code the tv will turn off.
attention: when the tv turns off you must immediately press the (ok) button to avoid the remote to go to the next code.
6 by pressing the (ok) button you have already stored the code. the (tv) button light will turn off.
Feb 05, 2017 | Universal Televison & Video
JVC LT-22EM72 Solid red power indicator but tv won't turn on
Customer service told me to leave the unit unplugged for 24 hours.
Feb 22, 2013 | JVC Lt22em72 22-in Led 60hz 1080p Hdtv
tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
tv is locked and wont turn on. i have no remote
Hello
If RCA tv has locked accedently and you haven't its original remote handset it is almost impossible to unlock it. Just try to get its original remote control from any of your friends or relatives who owns the same model of RCA set, borrow it from them for just unlock your set and try the following tricks. One amoung them will surely unlock your RCA.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset procedure is different depending on the model. Try each method until you find one that works:
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds.
  4. Hold down GO BACK on the remote and MENU on the front of the TV at the same time for at least 4 seconds.
  5. Hold down EJECT on the front of the TV and the MENU button on the remote at the same time for at least 4 seconds.
Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET.
Sinotec:
If you have the original remote (RC-A07) for Sinotec tv, then press and hold down the Music button for about 10 seconds
OK.
May 15, 2011 | RCA 24F512T 24" TV
my tv says fpa lock on and I can't get any channels what do I do?
Hello
To unlock your rCA TV, try out the following methods. One amoung them will surely unlock your TV. NB: You must have its original remote handset to operate with these tricks.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET
OK.
May 15, 2011 | RCA 14F512T 14" TV
109 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
