Tip & How-To about Office Equipment & Supplies
0x error
No matters which printer you are using if you get any error like 0x*****
please please donot perform any steps...please call HP teach support on 1800-474-6836...and if its needed they will replace the printer..
how to fix error 0xc18a0306
Hello jdeguzman982,
The error message starts with 0X usually be related to the a defective ink system or the defective cartrides. Please reffer the following HP document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3204788&tmp_track_link=ot_search
If the issue persists even after performing the steps provided in the above web link then the unit requires a hardware repair.
Regards,
Tony
Jul 15, 2011 | HP Photosmart C8180 All-in-One InkJet...
How do I fix the error: 0xc05d0381
Click here for steps recommended by HP to fix the 0x error, please reply if the issue persists.
Regards
Riztech
May 23, 2011 | HP Photosmart C7280 Printer
HP PSC1610 locks up with error
Please place any document on the glass bed and then press the copy button and then check if it copies with any error, also try multiple copies, if you get the 0x error again on the printer display, it is ink system failure error code that you get , let me know the result, I would provide you the further steps....
Nov 21, 2009 | HP PSC 1610 All-In-One InkJet Printer
Do I need a new printer scanner
Please perform the steps below to resolve the issue:
Step 1: 0x error Weblink
Step 2: Clean the Rollers
Step 3: Ensure correct installation of the front panel overlay
Step 4: Connect the All-in-One unit directly to wall outlet
Step 5: Power Cycle
Step 6: Semi Full reset
Sep 21, 2009 | Office Equipment & Supplies
FOR HP 5610 All in One error 0xd05d010d Reset power.
0x errors mean that the printer has an internal error within the firmware of the printer. There are not many steps to try except for a reset. This is a document from hp that you can use to do the reset and hopefully it will clear the error.
Jan 15, 2009 | HP Officejet 5610 All-In-One InkJet...
175 people viewed this tip
jasbo
jasbo
