Tip & How-To about Audio Players & Recorders
Method of reserving TrueHD audio and DTS Master Audio while backup blu-rays on Mac
Because of their wonderful and excellent acoustical properties, Dolby TrueHD audio and DTS-HD Master Audio can always provide people with amazing high-definition surround sound experience and put you right in the middle of the action. To experience the full potential of Blu-ray discs, people prefer to reserve the two terrific audio tracks while backup Blu-ray movies. The thing is that most Blu-ray programs are not good at recognizing both of the special audio tracks, fortunately, there are also some Blu-ray rippers have successfully added powerful support for Dolby TrueHD audio and DTS-HD Master Audio ,Pavtube Blu-Ray Ripper for Mac is one among them. If you are a Mac user, and looking for a program to help you keep TrueHD audio or DTS-HD Master Audio of your Blu-ray movie, as well as let audio and video match well during the process of copying, then this one is a nice choice.
Following contents will take TureHD audio as an example, and show you how to have access to Pavtube Blu-Ray Ripper for Mac to reserve your preferred audio track in detail. Hope you can get what you need from it Step 1: Load Blu-ray movies
Click "DVD Folder" or "IFO File" to import Blu-ray files.
Step 2: Select Dolby TrueHD audio, output format and specify save path
Tick off whatever .m2ts streams you want to copy. Generally speaking, select the .m2ts video stream with the longest playing time will be OK, because it is the main movie of the Blu-ray. Of course, if you would like to copy the extras of the Blu-ray movie, you can select several .m2ts files at a time, and check "Merge into one file" to combine them all to be as a single file.
Click the drop-down list of "Audio" option, then a list of audio tracks will be presented, and normally, the first one should be Dolby TrueHD, if in doubt, you can play them one by one to check which one is the proper Dolby TrueHD audio track you want.
Meanwhile, you should select output format from the drop-down list of "Format", here I choose "MKV HD Video (*.mkv) for instance, or if you just need copy Blu-ray movies without any quality loss and changing video format, you can select "Copy" and then "Directly Copy". After that, click "Browse" button to specify where to store the output files, if not, the program will export the output file to the default save path automatically, and these files can be easily found via clicking "Open" button as soon as copying work is completed.
Step 3: Set advanced settings
Click "Settings" button, and then you can adjust audio and video parameters such as video and audio codec, aspect ratio, bit rate, frame rate, sample rate, and audio channels on the interface showing below. To keep Dolby TrueHD audio to full extent, 6 channels is your choice.
Step 4: Start Blu-ray ripping
As soon as the above mentioned settings are finished, now just click "Convert" button to start [url=http://www.pavtube.com/blu-ray-ripper-mac/]Blu-ray ripping[/url], the ripping info including ripping process, time elapse, estimated left time, estimated file size, and generated file size are all shown clearly on the following window. In that way, you can make good control of your disk space as well as your time during the ripping process.
Learn more: http://www.pavtube.com/blu-ray-ripper-mac
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
How do I get audio from tv to receiver?
There should be audio output's on your TV and cable box. There are usually multiple options on most newer model a/v equipment. If u check the manual look for the page showing you about the various connections on the back, you're lookin for anything to do with audio output, there are many different types optical, digital, and analog. Again depending on your specific equipment there's almost always at least one way you can connect them
Feb 15, 2015 | Pioneer HTP-071 5.1 3D Home Theater System...
No Audio when I play Blu-Ray discs with Dolby TrueHD
For dolby digital to work you have to have the optical or coax cable hooked up to the reciever ,The HDMI cable is for digital video and audio output but does not support dolby digital out the cable into your reciever , so just turn off the dolby digital on your reciever and you should hear the sound.
here is more info
Dolby TrueHD is an advanced lossless multi-channel audio codec developed by Dolby Laboratories which is intended primarily for high-definition home-entertainment equipment such as Blu-ray Disc. It is the successor to the AC-3 Dolby Digital surround sound codec which was used as the audio standard for DVD discs. In this application, Dolby TrueHD competes with DTS-HD Master Audio, another lossless codec from Digital Theater System.
Dolby TrueHD uses Meridian Lossless Packing (MLP) as its mathematical basis for compressing audio samples. MLP was used on the earlier DVD-Audio format, but details of TrueHD and DVD-Audio differ substantially. A Dolby TrueHD bitstream can carry up to 14 discrete sound channels. Sample depths up to 24 bits/sample and audio sample rates up to 192 kHz are supported. Like the more common legacy codec Dolby Digital, TrueHD bitstreams carry program metadata. Metadata is separate from the coding format and compressed audio samples, but stores relevant information about the audio waveform. For example, dialog normalization and Dynamic range compression are controlled by metadata embedded in the TrueHD bitstream.
May 19, 2008 | Marantz SR-7200 Receiver
145 people viewed this tip
 Grubhead
Grubhead
