Tip & How-To about Computers & Internet
How to Disassemble an HP Pavilion DV6000
The HP Pavilion DV6000 is one in a popular line of consumer-oriented laptops produced by HP. Relatively inexpensive, the Pavilion DV6000 is a good all-around value for most users. Taking apart an HP Pavilion DV6000 is not an easy chore and if you plan to use the laptop again, it is important you know what you are doing or you have a large appetite for risk. If the above doesn’t describe you, consider taking the HP in for professional repair or upgrade. Otherwise, follow the steps below to disassemble the HP Pavilion DV6000.
1、Prepare a clear workstation. Turn off the laptop and remove all power components including the cord and the battery. (Turn the laptop over and you will find the tab to push and pop out the dv6000 battery.) Also remove any peripheral attachments like card readers and USB devices.
2、Turn the HP Pavilion dv6000 upside down and unscrew all the screws you find. Try to keep them separate by size so you can put them back in the same spot when and if you decide to reassemble the laptop.
3、Remove the hard drive and memory modules by pulling up on the rectangular compartments. The memory is located in the central compartment (remove by spreading latches and pulling up), and in most HP models the hard drive is located to one side.
4、Remove the optical CD/DVD drive by pulling on the drive face to the left and out of the laptop. Remove the WiFi card by disconnecting the gold connectors on the antenna and pulling the card from its slot.
5、Turn the hp dv6000 back over and remove the keyboard and power panel/media touch pad. Carefully pry the power panel up with a piece of hard plastic near the power button on the left side. Be careful when pulling not to yank the power connection as you might accidentally rip out a wire. Pull back the keyboard to reveal the connections. Disconnect the connections by carefully pulling on the tabs with your thumb and forefinger. If they are tight, wiggle them back and forth while pulling on them to loosen them.
6、Remove the screws that were underneath the power pack/media touch pad. Carefully pry up the top casing and set it aside.
7、Detach all visible connections to the motherboard by pulling gently on them, wiggling them if they are stuck. Gently pull up from the right side of the motherboard and remove. The HP laptop is now fully disassembled.
Computers & Internet Logo
Something about Replacement For HP Pavilion dv6000 Laptop Battery
you can buy replacement laptop battery from our site:www.buy-battery.ca We provide high quality and low price replacement batteries and chargers, such as Dell Laptop Battery, TOSHIBA Laptop Battery, Canon Cammera Battery, Nicon Camera Battery, Panasonic Camcorder Battery, JVC Camcorder Battery, Battery Charger, etc. All products are designed to be fully compatible with the original equipments. We buy in bulk and pass on savings to the customers. We have over 10,000 pieces of batteries & chargers in stock, and provide the best service to our customers.
Apr 01, 2010 | Computers & Internet
Can this HP Pavilion DV9000 adapter fit Presario V3000 laptop
just see it from http://www.udtek.com/hp-pavilion-dv9000-ac-adapter-90w-185v-49a-p-2970.html.may this is good for you.
Jan 15, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
I have a HP dv6000 laptop that needs a motherboard replaced. can you tell me how to do that?
hp has step by step directions on there website for full rebuild of the dv6000.. let me get you the link here now...
http://www.insidemylaptop.com/take-apart-hp-pavilion-dv6000-laptop/
Sep 30, 2009 | HP Pavilion dv6000z Notebook
I have a hp Parilon dv6000. The screem has gone
This is almost always an "inverter" or "backlight", which are both relatively inexpensive and easy to replace.An Inverter can run about $60 for the part itself, and a backlight about $5.00 .However to fix either problem ,you will have to take your screen apart. Almost anyone can replace an inverter with some common hand tools and a little care. I would not recommend trying to replace the backlight unless you are highly skilled at screen repair.
The bad news is that this can also be caused by a problem on your motherboard.
Aug 02, 2009 | HP Pavilion dv6000z Notebook
459 people viewed this tip
David Payne
David Payne
