Tip & How-To about Health & Beauty
How do i replace my battery in my hearing aid?
First you turn down your hearing device and open the latch on the inner side of the hearing aid,take out the old battery,then you simply pop in the new battery,shut the latch and put it right back into your ear.Then turn it on of course and your good to hear again.
Health & Beauty Logo
How do I removed the tailgate door liner panel on a 2005 Suzuki Grand Vitara JB?? There is no inner door latch to be removed. We cannot open the rear door as outer handle has broken. Help....many thx
The top bezel pops off. There are usually 2 screws to remove from the top of the bottom bezel on each side. start popping the bottom bezel off the hatch. It won't come out. Screws on the bottom. But you can get if off enough to reach down and grab the latch rod or latch to release the hatch. Yes the latch is at the bottom. And it has levers to move to open the hatch. Once open, remove the screws to remove the bezel, then replace the latch.
Jan 05, 2017 | Suzuki Cars & Trucks
need a cmos battery
This mobo uses a CR2032 litium battery, easily found, and cheap. To chage it, you must unplug the power cord, wait for a minute, remove the old battery (looks like a coin), behind the second PCI white slot. To remove the battery use a pair of tweezers and gently press sideways a small metal trap latch that holds the battery in place. The battery will pop out. Put the new battery in place, first on the opposite side of the latch and gently press down the battery in place till you hear a clic. Be careful with the battery's position. Positive side up, where are the trademark and model of the battery. Then, plug back the power cord. It will be necessary to reconfigure the BIOS settings.
Feb 04, 2013 | Intel D875PBZ Motherboard
cable is let go at the latch hood release now how can i open the hood so i can fix it
I had the same problem on a 1993 Buick Lesabre. I could not pop the hood using convention methods(handle on driver side). I have good news . . . in my case it isn't nearly as difficult as I had researched. It turns out all I had to do was take a flat screwdriver underneath the car to reach the latch from behind the radiator. First take the grill off. Once you get the grill off you will be able to see from the front where the latch is. It will be nearly centered from the front of the hood about 10 inches back and 1 inch below the top of the hood. If you look carefully you will see a hole in the middle of the hood latch device. In my case I could not pop the latch from this hole from the front(although I hear it may be possible). Once you find the latch from the front grill side, go up underneath the car and reach up from behind the radiator with your flathead screwdriver and try to feel for the latch with it. You may need to be VERY patient because you will not be able to see what you're doing. Don't drop your screwdriver.
After I popped the hood, I found that the latch had simply become dislocated and was an easy fix. The whole fix took about an hour. About 30 minutes to find the latch from underneath the car and about 30 minutes fix it.
Oct 30, 2011 | 1991 Buick LeSabre
hearing aids keep shutting down. Batteries get wet.
First you should probably keep your hearing aid and battery away from water.I suggest taking it out while in the shower/bath and cover your head with a hood or umbrella while out on a rainy day.If battery keeps shutting down then replace the old battery with a new one.If problem keeps accorring then maybe its time to take your hearing aid into your local hearing aid repair and let them solve the whole issue with why it keeps shutting down
Jan 19, 2010 | Sonic Health & Beauty
I just got a new siemens hearing aid and can not open the battery compartment it has a lock. The name on the aid is called intuis and I can open it a fraction but not all the way as it has a lock and I can not figure how to undue the lock part. it claims to push the slice to right to lock and left to unlock.
Sounds to me that you have inserted the battery incorrectly. If you are attempting to open battery door with any extra force( not normal), it sometimes will not release the door as you have the positive side of battery against the negative side in hearing aid shell.
Aug 15, 2009 | Health & Beauty
839 people viewed this tip
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
