Tip & How-To about Computers & Internet
How to start up faster, via enabling hibernation on your notebook.
Starting up much faster. When your computer hibernate, it stores whatever it has in the memory to the hard drive and then shut down. Once you power up again your computer come out of hibernation and return to it previous stated, and therefore booting up faster.
To enable hibernation on your computer do the following: On your desktop right click then go to properties, once in properties then go to Screen saver tab in there chose monitor power button. Once in the monitor power chose the tap for hibernation, then enable hibernation.
Computers & Internet Logo
I accidentally put my Compaq 6715 b laptop into hibernation. I don't know how I did it or how to bring it out of hibernation.
You need to hit the power button just the once to bring it back out of hibernation mode. It may take around 30 seconds until you hear your computer starting to boot back up and a little longer for the screen to come on.
Failing this, you can try a hard reboot by holding down the power button until you hear your computer re-boot. Usually you need to hold around 10 seconds. However using this last method as a final resort will result in your computer telling you that it did not shut down properly.
Aug 04, 2011 | Computers & Internet
after charging, my computer's battery lasts less than 2 hours. I've only had it since 2008 or after. Also once I unplug it the screen gets dimmer. Surely I don't need to get another battery! thanks Janet
Hi
Read the mention below note to increase your laptop battery life.
1. Defrag regularly - The faster your hard drive does its work - less demand you are going to put on the hard drive and your battery. Make your hard drive as efficient as possible by defragging it regularly. (but not while it's on battery of course!) Mac OSX is better built to handle fragmentation so it may not be very applicable for Apple systems.
2. Dim your screen - Most laptops come with the ability to dim your laptop screen. Some even come with ways to modify CPU and cooling performance. Cut them down to the lowest level you can tolerate to squeeze out some extra battery juice.
3. Cut down on programs running in the background. Itunes, Desktop Search, etc. All these add to the CPU load and cut down battery life. Shut down everything that isn't crucial when you're on battery.
4. Cut down external devices - USB devices (including your mouse) & WiFi drain down your laptop battery. Remove or shut them down when not in use. It goes without saying that charging other devices (like your iPod) with your laptop when on battery is a surefire way of quickly wiping out the charge on your laptop battery.
5. Add more RAM - This will allow you to process more with the memory your laptop has, rather than relying on virtual memory. Virtual memory results in hard drive use, and is much less power efficient. Note that adding more RAM will consume more energy, so this is most applicable if you do need to run memory intensive programs which actually require heavy usage of virtual memory.
6. Run off a hard drive rather than CD/DVD - As power consuming as hard drives are, CD and DVD drives are worse. Even having one in the drive can be power consuming. They spin, taking power, even when they?re not actively being used. Wherever possible, try to run on virtual drives using programs like Alcohol 120% rather than optical ones.
7. Keep the battery contacts clean: Clean your battery's metal contacts every couple of months with a cloth moistened with rubbing alcohol. This keeps the transfer of power from your battery more efficient.
8. Take care of your battery - Exercise the Battery. Do not leave a charged battery dormant for long periods of time. Once charged, you should at least use the battery at least once every two to three weeks. Also, do not let a Li-On battery completely discharge. (Discharing is only for older batteries with memory effects)
9. Hibernate not standby - Although placing a laptop in standby mode saves some power and you can instantly resume where you left off, it doesn't save anywhere as much power as the hibernate function does. Hibernating a PC will actually save your PC's state as it is, and completely shut itself down.
10. Keep operating temperature down - Your laptop operates more efficiently when it's cooler. Clean out your air vents with a cloth or keyboard cleaner, or refer to some extra tips by
11. Set up and optimize your power options - Go to 'Power Options' in your windows control panel and set it up so that power usage is optimized (Select the 'max battery' for maximum effect).
12. Don't multitask - Do one thing at a time when you're on battery. Rather than working on a spreadsheet, letting your email client run in the background and listening to your latest set of MP3′s, set your mind to one thing only. If you don't you'll only drain out your batteries before anything gets completed!
13. Go easy on the PC demands - The more you demand from your PC. Passive activities like email and word processing consume much less power than gaming or playing a DVD. If you've got a single battery charge - pick your priorities wisely.
14. Get yourself a more efficient laptop - Laptops are getting more and more efficient in nature to the point where some manufacturers are talking about all day long batteries. Picking up a newer more efficient laptop to replace an aging one is usually a quick fix.
15. Prevent the Memory Effect - If you're using a very old laptop, you'll want to prevent the 'memory effect' - Keep the battery healthy by fully charging and then fully discharging it at least once every two to three weeks. Exceptions to the rule are Li-Ion batteries (which most laptops have) which do not suffer from the memory effect.
Jul 20, 2011 | Toshiba Satellite P205D-S7802 Notebook
I accidently shut my computer down with hibernation before leaving. When I come home, the computer will not turn on, no lights no noise, nothing. How do I unlock the hibernation? Or could it be something else? Thanks
Jul 08, 2011 | Gateway 310X PC Desktop
Boot failure pentium 4
here is a temporary fix, but you may like it as a permanent one. Use the Windows hibernate mode. It actually works every time! Windows makes a "System screen shot" and stores it on hard drive and then powers off. Just be aware that you must ensure enough hard drive space for this. I am using this mode every day now. I think your system is trying to reject the power-saving features selected in Windows or at CMOS settings. Try turning off (or disabling) one feature at a time. I still think hibernate is the way to go. Here is a useful tip: to force hibernate (after it has been enabled) select START-SHUT DOWN and hover over STANDBY button and then hit the SHIFT key. The STANDBY button will turn into the HIBERNATE button. This is a quick way to enter hibernate. Remember to enable SYSTEM RESTORE mode so that if anything goes wrong during this "experiment", you can easily restore Windows system. I also use RESTORE but I also "clean house" once a month by turning it off and Disk scan and defrag and turning it back on.
Jun 24, 2007 | Intel D845WN (KD845WNPAK10) Motherboard
244 people viewed this tip
David Payne
David Payne
