Tip & How-To about Cell Phones
Installing a new screen for your Phone or PDA
You know the story your screen is cracked and ya can't see to use ya phone. What can you do? Simple replace the screen. It's easy.. well not that hard, as long as ya can follow instructions.
Here's how. First look on Ebay or the like for a suitable screen for your device, now these screens often also come with the necessary tiny special tools to dissasemble your device. look for one that has this service.
Most if not all screens simply "Clip/Plug" on to the mating board.
The same goes for Touch Screen elements too. These kits also often include a tutorial too. Plus there are a myriad of Forums and Posts on the Internet that will help you, simply search by your Phone by type and name.
So go ahead they are resonably cheap and they are easy to do.
Cell Phones Logo
broken iphone screen
There WAS A YOUTUBE video on how to do this as I bought an iPhone off ebay with cracked front and back. I was able to replace the back because that was fairly simple, but the parts are very small and you need a special tool to even take it apart. Replacing the front didn't look so easy. You pretty much have to take the phone apart which would be the easy part, but you'd have to remember what cables plugged in where and what screws of different sizes went where. You're better off taking it to a place that does this repair often!
May 21, 2014 | Apple iPhone 5S
how to replace lg venice cracked screen
I dropped my lg venice and cracked the screen. Is there an easy way to replace this?
Dec 13, 2012 | Boost Mobile Lg Venice No-contract Mobile...
how can i replace the screen
You will need a screwdriver that is really small its called a T6, 4 screws in the back of the phone and everything in the phone unplugs inside easy, if you know how to figure it out inside. Good LucK! FYI T6 is not an easy size to find, I found mine at Home Depo and it will only come in a set.
Dec 02, 2009 | Motorola Mobility Rival A455 Cell Phone
razr2 broken cracked screen
ya, be careful. i read online use a razor blade, jewelers screwdriver, etc to pry up on it, then take a piece of paper and work it back and forth till the screen is completely removed.
remove any bits of glass, then carefully clean off the old adheasive with a cloth or your finger. this is just what i read online. i am going to try this myself when i get the new glass screen in.
Feb 25, 2008 | Motorola Mobility RAZR V3
Cracked Camera
No easy fix. Pressure or impact is the usual cause of a cracked LCD. Try not to get the black stuff on anything....it's pretty toxic! The screen needs to be replaced (assuming there's no other, internal damage). They are usually in the range of $75 US.
Feb 19, 2008 | Nikon COOLPIX S200 Digital Camera
125 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
