Tip & How-To about Cell Phones
How to make Blu-ray .m2ts streams available for your PC and portable devices
To enable Blu-ray .m2ts streams to be available for playback on a PC or some popular portable multimedia players like iPod, iPhone, PSP, etc., the way of Windows users is to make use of AnyDVD HD to remove Blu-ray copyright protections as well as the region codes in the first step, and then have access to an M2TS converter to do format conversion in the second step. Apart from this method, another way is also practical, that is taking advantage of a Blu-ray ripper directly to complete this process once and for all. Since not everybody is clearly about the two ways, also because I have enough spare time currently, I will present the two solutions in a detailed way in this post, and hope it would be of some help for you guys who are hunting for this info.
Solution 1: with the help of AnyDVD HD and an M2TS Converter
What you will need:
- A Windows PC with a built-in Blu-ray drive or an external BD drive.
- AnyDVD HD
- Pavtube MTS/M2TS Converter
How-To:
1. Insert your Blu-ray disc to the BD drive, and run AnyDVD HD to remove copyright protections and region codes of your disc, no matter what kinds of protections your BD discs adopted, BD+, or AACS, AnyDVD HD is capable of dealing with them. Then you will get unprotected.m2ts files after the access of AnyDVD HD.
If you just want to watch the .m2ts files on your PC, you can use VLC media player, KMPlayer, or whatever to open these files for playback. If you need import them to your portable devices for playing, you should go on with the following step to do format conversion. Additionally, according to my own experience, VLC and KMPlayer sometimes are choppy while playing .m2ts files, suppose you want to watch them smoothly, format conversion is also recommended.
2. Convert .m2ts files to your wanted format (fit for your media players or portable devices)
In this step, Pavtube MTS/M2TS Converter will fully perform its functionality.
Step 1: Click "Add" button to input .m2ts files to this program
Step 2: Select output format and set destination folder
Click the pull down menu of "Format" to choose an output format according to your end use, this application provides a wide range of HD and SD formats output:
HD formats including .mkv, .mp4, .avi, .mov, .mpg, .ts, .wmv, etc.
SD formats including .avi, .mp4, .mkv, .mov, .wmv, .3gp, .flv, .f4v, .swf, .asf, .m4v, .vob, etc.
The output files can be added to iPod, iPhone, PSP, PS3, Xbox 360,Apple TV, Blackberry, Gphone, Zune, , Creative Zen, Archos, Nokia, Adobe Premiere, Sony Vegas, Windows Movie Maker, iMovie, Final Cut Express, Final Cut Pro, etc. for playback or editing.
Meanwhile, if you dislike using the default save path to store the output files, you can click the folder icon at the opposite side of "Output" to specify where to locate them.
Step 3: Click "Settings" button to adjust audio and video parameters
Codec name, bit rate, frame rate, sample rate, aspect ratio, and audio channels are all changeable in the popup window.
Step 4: Click "Convert" button to start conversion
Once finished, the generated files can be found out while clicking on "Open" button effortlessly. And then you can do whatever you like with the output files.
Solution 2: with the help of Pavtube Blu-Ray Ripper:
What you will need:
Pavtube Blu-Ray Ripper is an independent and professional utility to rip both Blu-ray discs and general DVDs to your wanted HD or SD media formats. With full Blu-ray disc support, it is able to remove copyright protections of your BD disc, no matter BD+, or AACS, even MKB Version > 10 is supported as well. With advanced audio technology, it is capable of reading all audio tracks of a BD disc, including Dolby TureHD Audio and DTS-HD Master Audio, which will never let you miss the mother tongue of the movie.
1. Insert your BD disc to the drive, and then run Pavtube Blu-Ray Ripper
2. Rip BD files to your wanted formats, directly copy is supported.
Step 1: Click "DVD Rom", "DVD Folder" or "IFO/ISO" to load Blu-ray .m2ts files
Step 2: Select output format and set save path
Click the drop-down list of "Format" to select your needed output format, and click the folder icon at the end of "Output" to specify the destination folder.
Step 3: Adjust audio and video parameters
Click "Settings" button, then you will be able to adjust bit rate, aspect ratio, frame rate, sample rate, audio channel in the popup window.
Step 4: Click "Convert" button to start Blu-ray ripping
Once the ripping task is completed, you can find out the output files via clicking on "Open" button.
The second solution seems more convenient, but if you already have an AnyDVD HD, you can consider adopting the first solution certainly. If you have none of them, then the second one would be a better choice. Compare with AnyDVD HD, this Blu-Ray Ripper is more powerful, taking removing copy protections aside, it allows users ripping BD disc to whatever format they want, as well as supports adjusting customized settings like bit rate, frame rate, resolution, audio track, etc to downsize your Blu-ray movie. Also, it’s much less cost is also a consideration, no more than $45 USD. Well, hope this helps.
Cell Phones Logo
How to Rip blu ray movies to hard drive with blu-ray movie ripper
blu-ray ripper is a very good blu-ray software.it can convert blu ray to any format. http://www.rip-blu-ray-copy.com/
Feb 20, 2010 | Garden
How to Rip blu ray movies to hard drive with blu-ray movie ripper Many blu ray users have asked: Is there a way to rip a copy of a blu ray movie to an external HDD and then play it back on iPod or other portable players? This Blu-Ray Converter makes the whole blu ray movie ripping process easy and fast. Converter Blu-Ray and general DVD to almost all the popular video and audio formats with high quality and converting speed. This BestHD Blu-Ray DVD Converter helps you share your Blu-Ray and general DVD movie or music on more portable players, like iPod, iPhone, Gphone, Apple TV, PSP/PS3, Xbox, Mobile Phone, Mp3 Player. Only get the part you like by setting the begin and end time for the conversion through the preview window and also can capture the beuatilful pictures of movie. Key Features: Rip Blu-ray DVDand general DVD movie to many output formats:Video:AVI, ASF, MPEG, MP4, WMV, MKV, MOV, FLV, SWF, RM, 3GP, etc. Audio: AAC, AC3, MP3, OGG, WAV, WMA, M4A, RA, Aiff, AU. Rip with high definition and highest rate. Enjoy Blu-Ray and general DVD on more multimedia devices: Apple TV, iPod, iPhone, GPhone, PSP\PS3, XBox, Mobile Phone, Windows Mobile.?Set detailed parameter to rip your Blu-Ray and general DVD into luxurious visual sumptuous dinner for all Shutdown PC automatically when conversion is complete. Preview movie artwork to the fullest. So if you want to share your Blu-Ray and general DVD movie or music on more portable players and capture the beuatilful pictures of movie, just use this software. What more you can get a discount if you buy it here:http://www.besthdsoft.net/best-hd-blu-ray-dvd-ripper.also you can download it here and just enjoy it. Good luck!
Feb 20, 2010 | Computers & Internet
111 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
