Tip & How-To about Washing Machines
Bad smell inside washer
Every Frontload washer on the market today has a smell issue or potential to have one quite easily.In fact the smell problem has been there since these Frontload washers were introduced. The real kick is instead of recognizing the problem and addressing it some of the manufacturers have even started selling consumers cleaners to help reduce the smell problem. Yes they are profiting on the sale of cleaners, that deal with an issue they created. The closest they have come to addressing the issue is adding an extra cycle to your washer strictly for cleaning the washer. Basically you clean your washer so it can clean your clothes. Why didn't the salesperson tell you about the issue? Maybe because it was his first day, but probably because he was trying to sell you a washer.
Now all this said, is there anything you can do? First and foremost make absolutely sure you are using a HE (high efficency) detergent. Frontload washers use a very little amount of water and the HE detergent is not only concentrated so you use less but it is not as thick as regular detergent so it has a better chance of washing away clean. Concentrated detergent is NOT HE detergent and still may pose an issue if used. If you Don't know what HE detergent is, call the manufacturer, your grocery store, or the sales guy who sold it to you. On average you will never need more than 2 tablespoons per load. DO NOT go by the cap fill lines ever. These lines make the assumption everyone has the same water, load the washers the same and have equally dirty clothes. More is NEVER better in a Frontload. Bottom line is you want to make sure all the detergent is getting cleaned out of the washer after each use. If any remains it will start to deteriorate and deteriorating detergent can smell.
Secondly when you are done using the unit for the day, use a towel to dry off the rubber door boot and the inner door. Don't be afraid to pull the boot some to get as much of the water off as possible. The rubber is pretty thick and sturdy. And if at all possible leave the door open as long as possible to help what water is left inside the washer to evaporate. The washers have vents on the back but they do not work as well as venting on a top-load washer. Basically the water drops will collect in the bottom after usage and if the door gets closed that water can get stagnant, grow bacteria and even mold. These will also cause lovely fragrances to tickle your nose.
Finally if you want to try some of the washer machine cleaners they may help some to clean away any buildup that may be already inside the washer. However it seems silly to pay so much for a washer and have to continually maintain a problem that is caused by the washer with cleaners produced by the washers manufacturer. If you try and cut back as much as possible (2 tablespoons) on detergent, and allow as much water to be cleaned out or evaporate the smells will resolve themselves. A good test to use if you think you have a buildup is fill the washer on it hottest cycle with the drum empty. Let it wash around for a few minutes and just look inside and see if you see suds. Suds in the washer tells you soap is still in the tub somewhere.
Washing Machines Logo
Frigidaire washer makes a very loud humming noise on spin cycle.
Good Morning Larry Looney, thank you for your post!
I understand that your Frigidaire frontload washer is making a humming noise while in spin cycle. This could be a potential problem with your motor or drum bearing. In order to find the proper cause of the humming noise I would highly recommend having a professional technician come out to your home for diagnosis and repair. This will help to avoid any unnecessary part purchases as well as any future issues. -Matt
Nov 14, 2014 | Frigidaire ATF6000ES Front Load Washer
hi can i install viber on my htc hd2 ? tnx avi
Hi, This is an official representative of Viber Media.
To be frank, we haven't thoroughly tested Viber on that device yet (due to the fact that it's still quite rare in the market worldwide), but we assume that it should generally work fine, with some potential incompatibility issues.
You may download it from the Market and we'd love for you to test it and let us know if anything goes wrong.
If you have more questions, we invite you to visit our Facebook page. Regards, Viber.
Sep 12, 2011 | HTC HD2 Smartphone
My dishwasher has a foul/ garbage like smell during/after running. Dishes do come out clean but the smell is really bothersome and it sometimes doesn't fully drain.
goto your nearest home depot they sell a product called affresh you use it on dishwashers there is also another version for frontload washers use this on your washers hotest cycle this removes mostly all smells if the smells persist you might want to check around the chopper area to see if you have any food enlodged around the chopper
May 18, 2010 | Whirlpool 24 in. DU900PCD Built-in...
Maytag Neptune Frontload....8 yrs old
hi there,
check the drain pump and the mold is quite common in front loading machines. you can use Affresh tables to remove it.
Sep 13, 2008 | Maytag Neptune MAH5500B Front Load Washer
193 people viewed this tip
Top Washing Machines Experts
