Tip & How-To about Computers & Internet
Logon to admin without admin account in 10 steps for Windows 7 .
1. Boot from your Windows 7 Installer Disk.
2. Launch Windows Recovery Environment.
3. Press Shift+F10 to launch Command Prompt.
Type the following inside the command prompt box:
4. copy "c:\windows\system32\magnify.exe" "c:\windows\system32\magnifybackup.exe"
5. copy "c:\windows\system32\cmd.exe" "c:\windows\system32\magnify.exe" /y
6. Restart your PC and click the "Ease of Access" icon on the bottom left corner of the logon screen.
7. Check the magnify box and click ok. It will launch the command prompt.
Note: change the word "name" with the current admin logon name you wish to logon.
8. net user name pass
9. Close the command prompt window.
10. Logon to the admin account using the password "pass".
Good Job, you can access your files that you already thought you lost. And you can change or remove the password in control panel now..
Disclaimer : This workaround should "not" be used to hack any other PC but yours. The purpose of this tip is to logon to your PC in case you forgot your admin password. Use at your own risk. The author shall not be liable if this workaround is misused in any unlawful way.
Computers & Internet Logo
password reset on dell 518
Reset Your Windows Password Using the Command Prompt
1. Boot your computer using your Windows installation disc.
2. Wait for the setup files to load, and select your language. Click Next.
3. Click the Repair your computer link on the Install Windows screen.
4. Select the operating system to repair, and note the drive letter on which the OS is installed (it is probably C: or D:). Click Next.
5. Click Command Prompt at the bottom of the list of recovery tools.
Now you need to overwrite the Sticky Keys executable with the Command Prompt executable. Sticky Keys is an accessibility feature that allows a user to tap the Shift, Ctrl, Alt, or Windows key once to achieve the same effect as holding the key down. Ordinarily, tapping Shift five times activates Sticky Keys--but with this trick, you are going to make tapping Shift five times activate the Windows Command Prompt instead.
The instructions below use drive letter C: as an example. If your operating system is installed on another drive, replace C: with the appropriate drive letter.
1. In the Command Prompt window, type copy c:\windows\system32\sethc.exe c:\ and press Enter.
2. Type copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. At the login screen, tap Shift five times. The Command Prompt will pop up.
4. Type net user username password, replacing username with your username and password with a new password.
5. Exit the Command Prompt, and log in using your new password.
To prevent another user from exploiting the same trick to reset your password, you can restore Sticky Keys as follows:
1. Step through the instructions above to boot the PC using your Windows installation disc, open the recovery tools, and launch the Command Prompt.
2. Type copy /y c:\sethc.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. Pressing Shift five times will now activate Sticky Keys instead of the Command Prompt. Store your Windows installation disc in a secure location.
May 03, 2014 | Dell Inspiron 530 Desktop Computer
windows 7 will not start
First you need to try safe mode and check if you are able to boot to the system....
If not then ...
Note this issue is caused due to the boot file corruption and in order to troubleshoot this issue we will run chkdsk from Win RE (Windows Recovery Environment )mode and check for the issue, to do that follow the below steps.
To run check disk, you have to have Windows 7 DVD, boot the computer to Win RE from the elevated command prompt, and try to do a CHKDSK. You can follow these steps to run CHKDSK :
1) Use the Windows 7 DVD to start the computer in Windows Recovery (WinRE).
2) In WinRE, open a command prompt. To do this, follow these steps:
On the Install Windows screen, select the appropriate Language to install, Time and
currency format, and Keyboard or input method options, and then click Next.
3) Click Repair your computer.
4) Click the 7 installation that you want to repair, and then click Next.
5) Click Command Prompt.
At the command prompt, type the following command, and then press ENTER:
chkdsk drive: /f and chkdsk drive: /r
source link
Jan 14, 2013 | Computers & Internet
Windows XP SP2 Repair
Solution: Rename the C:\WINDOWS\SYSTEM32\CATROOT2 folder to something such as catold to prevent WinXP's Setup program from locating the folder and halting the installation. If you are still in Setup, press SHIFT-F10 to launch a command prompt from within Setup. At the command prompt, type cd\win dows\System32 to open the System32 folder and then type rename CATROOT2 catold, press ENTER, restart the computer, and attempt the upgrade again.
If you cannot reach a command prompt from Setup, reboot the computer from a Win95, Win98, or WinMe startup disk and rename the folder from the command prompt. You can also launch a command prompt by booting from the WinXP installation CD and running the Recovery Console.
Mar 25, 2009 | Toshiba Satellite 5105-S501 Notebook
149 people viewed this tip
David Payne
David Payne
