Tip & How-To about Cell Phones
No Network - Cell Phone
Today, i would help you to Fix a Common issue with Most of the Cell Phones - No Network.
The below mentioned Points should be Considered to Fix this :-
1. The First thing, i have Found with most of the Handsets is that they are LOCKED. Make sure that the cell phone you are using should be Unlocked. In case, it is Locked, Contact the Original Service Provider and get the Code to Unlock or you could Search Different Sites who claim to Offer that ( Note - I never used any Site and i am not aware whether it would be Hit or Miss ).
2. Make sure that there could be a Signal Problem. There are Cases, when you Cell Phone could Read ' Emergency Only ', if there is No / Less Network in that Area. Try to Use it away from that Place. If that is the same problem, then you need to troubleshoot the Cellphone.
3. Have you tried Setting it for Manual Network. In Most of the networks, Automatic Network Search is Set as Default. Change it to manual and Search that. Usually this would work on most cases.
4. Network catching Capability also Depends on the Handset. No two Handsets could have the Same Capability. You could try to Use ' Network Boosters ' which is available with most of the Online Vendors or Local Shops.That could really help the cellphone to Catch Network.
5. If it still shows Message like ' Emergency Calls ', then it could be a Defective Antenna. Take another Set ( Same Model ) and Compare, is that an issue with Both Sets or Your Set. If that is Only with your Handset, you need to send the Cell for repair.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Cell Phones Logo
how to fix pocket s5300 no registered network
First you need to find out what is the reason behind this "not registered on network" error coming out of your Samsung Galaxy Smartphone. Points to be noted are given below along with their solutions
Oct 28, 2015 | Samsung GT-S5300 Galaxy Pocket
Hi. Please help i cant use Globe network as my internet for my HTC Wildfre. Please help the correct settings of mobile network. thanks
1. Go to Settings->Wireless & Networks->Mobile Networks->Access Point Names
2. Click Menu->New APN and follow the setting below (leave settings as is for those not mentioned)
  • Name: Globe Internet
  • APN: http.globe.com.ph
  • APN type: default
3. After saving the settings above, select the newly created APN (green radio button appears).
Your phone is now configured to use the newly created APN.
May 04, 2011 | HTC Wildfire Cell Phone
I astray the serial of my plowing how do I get the serial diner that no I can go with my lapto to the network Wireless is the numbering of the detachment posterior part of him plowing my Dynex agredeseria in advance for your help elvis coronado
If i am able to understand your problem, you have lost the network key ( or the password you have set to your router for security purpose )
If this is the issue, i will be able to help you find the key for your network ( it is called WEP or WPA or WPA2 key )
Follow the instructions below and you will be able to fix the issue. Click on the link given below.
Link
Nov 02, 2010 | Dynex Wireless-G Broadband Router
my acer travelmate 5320 wont let me access the internet please help
mentioned below are some steps which will help you with checking if everything is fine (also assuming that the acer is able to go online wired)
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
Once you complete the above task you may follow the below mentioned step.
Following the below mentioned step will help the Microsoft to take control over the card and try to connect (instead of the software provided by the card manufacturer to control the device)
Nov 09, 2009 | Computers & Internet
I can't access the web on my cell, keep getting error 67, somebody help me, tech support was useless. Thanks.
This is a common problem with Sprint Phones. You never mention, Make, Model and the Service provider?
Have you tried to reconfigure the whole settings once again? If not, try it.Along with that, go for a Hard Reset and check, if that could fix the issue, If not, let me know so that i could help you further.
Let me know, if needed further assistance.
Hope i helped you.
Oct 23, 2009 | Cell Phones
2,044 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
