Tip & How-To about Computers & Internet
How to print to a PDF file with any program NO printer needed.
There are a lot of reasons to print to a .pdf file. Most of the times it will be for backup purposes. A lot of times you get confirmation numbers or other important things. Well not always do you want or need to waste paper to save the information. Printing to a pdf file has a million great uses and here is a great and easy way to do that. There are a lot of programs available that offer this feature but here is a small, easy and FREE one that works great:
Step 1: Follow this link: http://www.dopdf.com/
Step2: When you are on that page just click the get it link at the top and that will open the download dialog box.(red arrow points to it)
Step3: Download the program
Step 4: Run/install the program. Select your language. Then click next
Step 5: You can click next on every new window and then click install. Then click finish and you are done. Note: One option that you may want to select is setting dopdf to default. If you feel you will be using a lot then you may want to select this option now. Otherwise feel free to click next until you click install and then finish.
Then you are all set and ready to print to pdf. When you print in any program just make sure dopdf is in the pull down box. Like the picture below. Thank you so much and enjoy -LeeTheDeuce
Computers & Internet Logo
every time i export to pre press pdf file it does not safe the content of the file, only the crop marks (corel x5)
Try using a different PDF conversion software ...
http://www.verypdf.com/
This works just like a print function, but it prints to a file instead of onto paper. I have used this software for quite some time and I have never had a problem, though it is sometimes a little difficult to make sure page breaks from MS Notepad line up properly. Trial and error works with this system, since you can print to the PDF file, then view the PDF to make sure it looks perfect. There may be better software out there for this purpose, but this is effective and easy to use in a pinch.
May 23, 2011 | Computers & Internet
How to remove PDF Password Securty ?
Forgot PDF password? it is your better choice to use PDF password recovery 5.0, a efficient and highly appreciated tool to unlock PDF password. GO TO its official site for more info.
Nov 29, 2010 | Computers & Internet
Cannot duplex print pdf files. No problem for over 2 years until now. Word docs OK have tried changing printing settings and default but problem persists. Advice would be really appreciated. Thanks
Printing PDF files without special software can be a problem, if you print a lot of files of different formats and need to deal with a few printers.
Total PDF Printer from Coolutils is a program features a lot of printing modes and adjustable parameters that will help to optimize the process of printing PDF files. To save the paper, it offers ability to print PDF files in duplex mode, i.e. print PDF pages from both sides of paper sheet.
You do not need to turn each sheet by your hands, as the program changes printer settings so that this process is automated.
Total PDF Printer is a perfect suit for personal or professional use for printing PDF files. It automatically connects to all printers enabled in the system and redirects printing tasks to the trays you specify.
Print PDF Files In Duplex Vertical
Feb 07, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
139 people viewed this tip
David Payne
David Payne
