Tip & How-To about Office Equipment & Supplies
How to Repair HP Printer
HP (Hewlett-Packard) is well known for manufacturing electronic gadgetswhich are reliable and cost effective. In terms of customersatisfaction it is creating new mile stone. hp has introduced excellentprinter models in all ranges to meet the demands of both home andbusiness users. But due to some common issue, you may undergo afrustrating experience.
But don’t get down with your temper. There are leading solutionproviders in the market who can do the HP printer repair with greatsatisfaction. Even with simple knowledge you can also perform littlebit of HP printer repair work. Follow this article to resolve some ofyour printer issues:
1. If there is some paper jam issue, make a test printing. Observe thesound of your printer. Notice, how long the paper proceeds. If there ismultiple trays in your printer, try with different tray there might beissue with your paper tray. Its roller may have corrupted. You mayobserve the surface of the roller with your hand. You can replace theroller if required.
2. Follow the manuals to fix the new roller, slide it onto the prongand push it all the way in. You would hear the click sound. Hence, yourHP printer repair job is over. You can print a page for trail.
3. Issue pertaining to cartridges can be addressed in an easy manner.Open the left-hand door and look for the cartridge. Remember, don’tperform it when your printer’s fuser is hot, and allow it to cool.Firmly remove the fuser by lifting the locked hinges. Observe theroller of the fuser, if they are seized it means they need to bereplaced. Slide the new fuser cartridge and flip the levers to thelocked position. Power on the printer and make a trial. Most probably,this could solve your purpose and HP printer repair has been successful.
4. Some times you may not be getting any power on your hp printer evenwith proper power supply. In the situation you can do HP printer repair work by a smart judgment with the power cable used. Remember, laserprinters use a standard power cord, deskjet and photo printerstypically use a proprietary power supply. Again, observe the powerbrick, it should be warm but not hot. If it is getting overheated thenreplace the cable.
Won't accept compatible cartridges since HP update
You can still use original manufacturer's cartridges.
Oct 23, 2015 | HP Deskjet 3050A e-All-in-One Photo...
what is hp
HP is short for Hewlett Packard, it is one of the major computer manufacturers such as Dell and Toshiba.
Mar 21, 2011 | Computers & Internet
My laptop will not charge when the charger is plugged in. I tried removing the battery and turning it on while it was plugged in. Is my computer messed up or is it just the charger. Also my warranty has expired so Whats this going to cost me.
Your laptop still not charge even with the battery removed?
I guess you need a new adapter. Or you can test with a known working adapter first.
Specification of HP pavilion DV7 charger:
Output: DC19V 4.74A
DC Connecter (Barrel) size:
Internal Diameter: 5.0mm
External Diameter: 7.4mm
With central smart-pin inside
Reference: http://www.chargerbuy.com/replacement-hp-pavilion-dv7-ac-adapter-19v-4-74a.html
Feb 16, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
453 people viewed this tip
jasbo
jasbo
