Tip & How-To about Televison & Video
Samsung 940MW no power or slow to show picture
The Samsung 940MW Monitor/TV units have a known issue with the power supply, as do many LCD monitors. The problem is heat buildup in the case causes parts called capacitors to overheat and blow out, killing the power supply. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Televison & Video Logo
help with power/ on
The normal cause of power up problems is a failure in the power supply. Check out this repair guide that shows how to disassemble the unit, what to look for and how to repair the monitor.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/
I hope this helps.
BuddyMc
Mar 18, 2012 | Samsung SyncMaster 940MW 19" LCD Monitor
I have samsung syncmaster 940mw monitor. The monitor for the most part will not turn on. When the power button is pushed or attempt to turn on with the remote the little green pilot light will blink or flash but the display will not lite up or come on
That is a hell know problem with the 940MW tv/monitors. The power supply has failed because of parts called capacitors have shorted. If you can solder then you should be able to repair your monitor. Here is a link to the repair guide for this issue.
I hope this helps, if so please rate my solution.
Oct 30, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
on and off switch not working
Hello Michael,
The most common problem with the Samsung 940MW units that don't turn on is a failure of the power supply board. There are parts called capacitors that fail which in turn causes the power supply to not startup correctly so the monitor never powers up. Here is a link to a repair guide that should get you back watching tv and using the monitor in no time.
Oct 13, 2011 | Samsung SyncMaster 940MW 19" LCD Monitor
Samsung SyncMaster 940MW 19" LCD Monitor keeps going blank
Before you spend a lot of money on the unit look over this article we have posted on our web site: http://www.ccl-la.com/blog/index.php/repairing-the-samsung-940mw-lcd-tv/ If you can solder then you should be able to do the repair yourself. The power issues you have are usually caused by a failure in the power supply board. If you don't want to do the repair we do offer repair services, more details on this can be found here: http://www.ccl-la.com/blog/index.php/service-request-form/
I hope this helps, if so please rate our solutions.
Buddy
Corporate Computer
www.ccl-la.com
May 03, 2010 | Samsung SyncMaster 940MW 19" LCD Monitor
power light was blinking took a long time to turn on, now power light does not blink or go solid and screen does not work
The Samsung SyncMaster 940MW monitor has an issue with the power supply going out. The flashing power light or not turning on are the classic symptoms of this issue. Check out our web site at: www.ccl-la.com This model is on Monitor repair page #2 We have a step by step repair guide posted that will guide to doing the repair yourself. It involves changing a few capacitors on the power supply. If you can solder then you should be able to do the repair yourself. If you don't want to do the repair we do offer a repair service for $35 plus return shipping. If you have any additional questions just let us know at: tech@ccl-la.com
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Samsung SyncMaster 940MW 19" LCD Monitor
272 people viewed this tip
Top Televison & Video Experts
