Tip & How-To about Cell Phones
How to correct sim card error / insert sim card Procedure to follow Step 1: Check the sim tray or sim seater to see if it it broken, if it is, replace it Step 2: If the sim seater/tray is not broken, clean the entire terminal. Step 3: If the sim seater/tray is not directly on the board, trace the broken led and solder it, or you replace the broken led with another sim tray. Step 4: If it is still not working, change the battery and put a new battery, because a virus infected battery will always give such problem. Step 5: Finally, if the problem still persist, then check the sim card and replace with another sim card if the former is bad because a bad sim card will always display such message as insert sim card or sim card error.
Cell Phones Logo
Nokia E72 insert sim problem soleb
- Clean the sim card tray - see whether the sim card tray led is broken (if so replace it) - If the problem still persists replace the battery. - If still the problem persists check the sim card (try it any other phone)
Hope this helps, thanks!
Sep 12, 2011 | Nokia E5 Cell Phone
i put the sim card in and it says insert sim card
Hi, when a phone says insert Sim,is either the Sim card or the Sim seater that allows the Sim to work is bad.
First try the Sim card on another phone and see if it will display insert Sim again.If it display that means the Sim card is damaged. But if no display,that means the Sim tray of your phone is damaged and will need to be replaced.
Contact a skill prsonnel.
Take care.
Aug 06, 2010 | Pantech Slate Cell Phone
sim card promblem
Procedure to follow
Take care
May 07, 2010 | Pantech Slate Cell Phone
Sim card
Procedure to follow
Take care
Apr 13, 2010 | O2 Samsung SGH-E250 Cellular Phone
I am getting an error message of 08.055.44:9347. Every time we go to print the page is blank.
8,055.44: The Media Drive stalled while engaging headtilt.
Troubleshooting Procedure for Wiper/Media Gearbox
Step Questions and Actions Yes No
Check for obstructions in the Wiper
Assembly path.
Is the Wiper Assembly obstructed by the
Printhead or wiring?
Clear any
obstructions.
Go to Step 2.
2 For an 8,005.48 error:
1. Check for paper in the paper path that is
adding drag to the rollers. Look for paper
or wiring interfering with the take away
roller.
2. Remove the Tray 1 Pick Solenoid to view
the meshing of the Take Away Roller’s
gears to the Media Drive Assembly.
Did this correct the problem?
Complete. Go to Step 5.
3 For an 8,007.41 error:
Check for a missing KL-clip securing the
Head Maintenance Clutch. Replace if
missing.
4 For an 8,009.43 error:
1. Ensure that there is no paper in the paper
path adding drag to the rollers.
2. Ensure the Media Drive Assembly is fully
seated and correctly installed.
3. Remove the Tray 1 Pick Solenoid to view
the meshing of the take away roller’s
4. Ensure the feed rollers are properly
engaged in the drive gears.
Complete. Replace the
Media Drive
Assembly.
5 Run the Wiper Drive test.
Did the test pass?
Go to Step 6. Go to Step 7.
6 Run the Wiper Alignment test (see “Wiper
Alignment Procedure” on page 6-2).
Did the test pass?
Go to Step 8. Go to Step 7.
7 1. Inspect the wiper system for improper
operation, obstructions, or damage
(broken gear or belt). Look for ink in the
Wiper Belt channels.
2. Ensure the wiper system is properly
aligned (see “Wiper Alignment
Complete. Go to Step 8.
8 Run the Head Maintenance Clutch test.
Did the test pass?
Go to Step 9. Replace the
Head
Maintenance
Clutch.
9 Is the head lock mechanism on the right end
of the Exit Module functioning properly?
Go to Step 10. Replace the
Exit Module.
10 Are there obstructions or spilled ink on the
Wiper Blade, the Head Tilt Gear drive path,
or under the Printhead?
Is the Waste Tray overfilled?
Clean the
inside of the
printer and
retest.
Jul 31, 2009 | Xerox Phaser 8400 Laser Printer
797 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
