Tip & How-To about Office Equipment & Supplies
ERROR codes Canon 8580
Canon 8580 E000 The temperature of the upper fixing roller has not increased above the specified level 90 seconds after switching power on. The temperature of the upper fixing roller does not reach 150 C within 8 minutes after switching power ON. The temperature of the upper fixing roller does not reach 180 C within 5 minutes of reaching 150 C. The temperature of the upper fixing roller drops below 50 C during STANDBY. E001 The temperature of the upper fixing roller exceeds 250 C. E005 The length of fixing assembly cleaning belt wound on the take-up reel exceeds the specified length. E010 When two or more clock pulses are not inputted for a period of 2 seconds after a MAIN MOTOR DRIVE command is generated. E011 When excessive current is detected by the fault detection circuit of the DC driver PCB. When excessive current is detected by the fault detection circuit of the duplexing unit driver PCB. When excessive current is detected by the fault detection circuit of the scanner motor driver PCB. E020 When a toner out signal (TSP) is emitted from the developing assembly for a total of at least two minutes. E050 When the HOLDING TRAY HOME POSITION signal (THP) is not generated within 4 seconds from the beginning of HOLDING TRAY MOTOR DRIVE command (TMDP1,2) When the HOLDING TRAY HOME POSITION signal (THP) is generated for at least one second while the HOLDING TRAY MOTOR DRIVE command (TMDSP1,2) is being generated. E203 When two or more clock pulses are not inputted from the SCANNER MOTOR DRIVE command is being generated. E210 When the LENS HOME POSITION signal (LHP) is not generated within 4.8 seconds after the power switch or door switch goes ON. When the LENS HOME POSITION signal (LHP) is generated for 2 seconds or more. E243 When an abnormally in communication occurs between the microprocessors on the DC controller PCB and those on the control panel PCB. E400 When an abnormality in communication occurs between the DC controller PCB detect RDF controller PCB. E401 When a flag mounted on the pick-up roller HOME position sensor (S3), it indicates that M1 is turning. S3 should go ON and OFF two or more times in one second. E402 The number of pulses in a 200 ms period is too low. E403 When the number of feed motor clock pulses in a 200 ms period is less than the correct value. E411 When the sensor output is greater than 2.3V when there is paper. E500 When an abnormality in communication occurs between the DC controller PCB of sorter detect main controller PCB. E510 When there is no pulse output from the feed roller motor and when the first copy jams. E540 The lead can HOME position sensor does not go "OFF" within 0.5 second after the BIN MOTOR DRIVE signal (BMON) is output. E541 The lead can HOME position sensor does not go "ON" within 1.0 second after the lead cam position sensor goes "OFF".
how to remove the E5 error
hi
pls vote me to keep me alive
Nov 23, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error E000 on Canon NP 6317.
IX. SELF DIAGNOSIS The DC controller PCB has a microprocessor that diagnoses the functions of the copier (particularly the sensors) at appropriate intervals. If this microprocessor detects an abnormality, it will display the type of the abnormality on the indicator on the control panel. The table below shows the various fault codes, their meaning, and the corresponding detection timing. Example of E000 code indication: Eó000 light alternately. Fault criteria • If the temperature difference between the thermistors 1 and 2 is 60°C or higher. • If the fixing asssembly temperature is lower than 50°C after 15 sec from the power-on. If the tempereture remains 220°C or higher for 0.1 sec or longer. If warm-up is not over after 60 sec from when the temperature reached 50°C. If fixing unit temperature drops below 50°C when the copier is in stand by or copying. If the C HEAT CHECK signal is on while the HEAT ON signal is off. If the main motor speed feedback signal does not appear after 2 sec from the main motor. If the break signals is generated continuously for 0.1 sec or more when the counter is not being driven. Code displayed Main cause Fixing roller heater (LA1) low temperature error Thermistor1 (TH1), Power supply assembly, Fixing roller heater (LA1), or DC controller PCB Fixing roller heater (LA1) low temperature error: Thermistor, fixing roller heater, AC driver, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing roller heater (LA1) low temperature error: Thermistor (TH1), fixing roller heater, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing heater ON timing error: Triac (U104) on power supply assembly Main motor error: Main motor (M1), DC controller PCB Counter (CNT1), DC controller PCB E000 E001 E002 E003 E004 E010 E030
Jan 05, 2010 | Canon Office Equipment & Supplies
canon imagerunner 2230
try to clear in service mode touch Additional funcion key then 2 8 at same time then additional func key again in that order screen should change to service mode then touch copier then function then clear then err then ok then turn off machine using main switch if it wont clear you have a bad fuser
Dec 02, 2008 | Canon IMAGERUNNER 2230 Copier
200 people viewed this tip
k24674
