Tip & How-To about Office Equipment & Supplies
ERROR codes Canon 8530
Canon 8530 E000 The surface temperature of the fixing assembly upper roller fails to rise by a specified value within 90 sec after power-on. The surface temperature of the fixing assembly upper roller fails to reach 150 C within 8 min after power -on. The surface temperature of the fixing assembly upper roller fails to reach 180 C within 5 min after it has reached 150 C. The surface temperature of the fixing assembly upper roller falls below 50 C in standby. E001 The surface temperature of the fixing assembly upper roller exceeds 250 C. E005 The cleaning belt inside the fixing assembly has been taken up more than a specified length. E010 After generation of the main motor drive signal, two or more pulses are not received within 2 sec. E020 The accumulative time during which the toner supply signal (TSP) has been generated by the developing assembly reaches 3 min. E050 The holding tray home position signal (THP) is not generated within 4 sec while the holding tray motor drive signal (TMDP1,2) is being generated. The holding tray home position signal (THP) is generated 1 sec or more while the holding tray motor drive signal (TMDP1.2) is being generated. E13 The error detection circuit on the waste toner feed motor driver PCB has detected on overcurrent. E203 Input of two or more clock pulses is not received within 2 sec from the scanner motor drive signal is generated. E210 The lens home position signal (LHP) is not generated within 4.8 sec after the power switch or door switch has gone ON. The lens home position signal (LHP) is generate 2 sec or more. E240 An error has occurred in the microprocessor on the DC controller PCB. E243 An error has occurred in the communication between the microprocessor of the DC controller PCB and the microprocessor in the control panel. E710 An error has occurred in the communication between the DC controller PCB and the controller PCB of the option, and the DC controller has detected the error.
how to remove the E5 error
hi
Canon 8580 E000 The temperature of the upper fixing roller has not increased above the specified level 90 seconds after switching power on. The temperature of the upper fixing roller does not reach 150 C within 8 minutes after switching power ON. The temperature of the upper fixing roller does not reach 180 C within 5 minutes of reaching 150 C. The temperature of the upper fixing roller drops below 50 C during STANDBY. E001 The temperature of the upper fixing roller exceeds 250 C. E005 The length of fixing assembly cleaning belt wound on the take-up reel exceeds the specified length. E010 When two or more clock pulses are not inputted for a period of 2 seconds after a MAIN MOTOR DRIVE command is generated.
pls vote me to keep me alive
Nov 23, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Error E000 on Canon NP 6317.
IX. SELF DIAGNOSIS The DC controller PCB has a microprocessor that diagnoses the functions of the copier (particularly the sensors) at appropriate intervals. If this microprocessor detects an abnormality, it will display the type of the abnormality on the indicator on the control panel. The table below shows the various fault codes, their meaning, and the corresponding detection timing. Example of E000 code indication: Eó000 light alternately. Fault criteria • If the temperature difference between the thermistors 1 and 2 is 60°C or higher. • If the fixing asssembly temperature is lower than 50°C after 15 sec from the power-on. If the tempereture remains 220°C or higher for 0.1 sec or longer. If warm-up is not over after 60 sec from when the temperature reached 50°C. If fixing unit temperature drops below 50°C when the copier is in stand by or copying. If the C HEAT CHECK signal is on while the HEAT ON signal is off. If the main motor speed feedback signal does not appear after 2 sec from the main motor. If the break signals is generated continuously for 0.1 sec or more when the counter is not being driven. Code displayed Main cause Fixing roller heater (LA1) low temperature error Thermistor1 (TH1), Power supply assembly, Fixing roller heater (LA1), or DC controller PCB Fixing roller heater (LA1) low temperature error: Thermistor, fixing roller heater, AC driver, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing roller heater (LA1) low temperature error: Thermistor (TH1), fixing roller heater, power supply assembly, DC controller PCB, thermoswitch (F1), auxiliary thermistor (TH2) Fixing heater ON timing error: Triac (U104) on power supply assembly Main motor error: Main motor (M1), DC controller PCB Counter (CNT1), DC controller PCB E000 E001 E002 E003 E004 E010 E030
Jan 05, 2010 | Canon Office Equipment & Supplies
im facing one problem if e 004 what is the
VIII. SELF DIAGNOSIS The microprocessor on the copier’s DC controller PCB is equipped with a function that checks the condition of the machine (especially the condition of sensors). It runs checks at such times as programmed, and will indicate any fault it finds in the form of code. A. Copier E000 • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has a short circuit. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The thermistor (TH1, TH2) has poor contact or an open circuit. • The fixing heater (H1) has an open circuit. • The thermal switch (TSW1) has turned on. • The triac is faulty. • The DC controller PCB is faulty. • The triac has a short circuit. • The DC controller PCB is faulty. • The surface temperature of the fixing upper roller does not reach 40°C within 14 sec after power-on. • The surface temperature of the fixing upper roller exceeded 230°C. • The surface temperature of the fixing upper roller does not reach 60°C within 10 after it exceeded 40°C. • The surface temperature of the fixing upper roller does not reach 80°C within 10 sec after it exceeded 60°C. • The surface temperature of the fixing upper roller does not reach 100°C within 10 sec after it exceeded 80°C. • The surface temperature of the fixing upper roller does not reach 120°C within 10 sec after it exceeded 100°C. • The surface temperature of the fixing upper roller drops to 130°C or less after it reached the target temperature (160°C) for standby. • The triac is identified as having a short circuit. Code Cause Description E001 E002 E004 E003
Oct 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
468 people viewed this tip
k24674
