Tip & How-To about Office Equipment & Supplies
ERROR codes Canon 6150
Canon 6150 E000 Thermistor E001 SSR E002 Thermistor, ht. Lamp thermal fuse or SSR E003 Thermistor, ht. Lamp thermal fuse or SSR E005 Fuser cleaning belt E010 Main drive problem E020 Toner motor, toner level sensor, toner hopper sensor E030 Counter E050 Duplex problem E203 Scan home problem E210 Lens home sensor E401 Document feeder paper pickup motor E402 Document feeder belt clock pulse problem E403 Document feeder main motor clock pulse problem E411 Document feeder sensor problem E500 Sorter/copier interface problem E510 Sorter motor drive E530 Sorter home sensor E531 Stapler swing sensor E540 Sorter lead cam home sensor E541 Sorter lead cam home sensor E710 DC controller board E711 DC controller board E712 Document feeder problem
Error Code E000001-0004
The main thermistor TH1 has poor contact or open circuit.The thermal switch TP1 has an open circuit.The fixing heater has an open circuit.The SSR is faulty or the DC controller PCB.After the main power switch is turned ON the temperature detected by the main thermistor does not reach 70 C.The error must be reset in service mode :COPIER - FUNCTION - CLEAR - ERR
Jan 19, 2010 | Canon imageRUNNER C3200 Copier
the canon ir2016 j displays E003 nd i know its fixing but i can't fix it what shall i do?
ferst solved[ astrix 2 8 astrix} servise mode athore ways replase fuser elament. E000 Fuser temp low. Heat lamp, thermoswitch, thermistor, SSR E001 Fuser temperature too high or shorted thermistor E002 Fuser temperature too low E003 Fuser temperature too low E004 SSR, or lamp reg. board E010 Drive problem E022 DV unit switching problem E030 Counter not working/open E202 Scan problem. Scan sensor, scan motor E204 Scan problem. Scan sensor, scan motor
Jan 18, 2010 | Canon iR 2016i Black and White Copier
System error E000
E000 Fuser thermistor, heater thermal fuse E001 Fuser thermistor, or triac E002 Fuser thermistor, thermal fuse or triac E003 Fuser thermistor, heater, thermal fuse or triac E004 Triac or fuser won't shut off E007 Fuser film is off center or not driving properly. Might be able to reset in service mode 4-407 E010 Main motor drive problem E030 Counter E041 Paper deck motor, clutch or sensor E064 Composite power supply or main motor board E202 Scan problem. Motor sensor E210 Lens drive problem E220 Exposure lamp E240 Main board or composite power supply E260 Main board, power supply cooling fan or composite power supply E261 Composite power supply or fluctuating power E400 ADF communication to machine E401 ADF pickup motor or sensor E402 ADF belt motor drive E403 ADF feed motor or slip sensor E404 ADF exit motor E411 ADF document detect, or registration sensor or edge sensor E500 Sorter communication problem E510 Sorter drive problem E530 Stapler guide b
Jan 06, 2010 | Canon Office Equipment & Supplies
281 people viewed this tip
k24674
