Tip & How-To about Polycom VSX 6000 (220022222001) Video Conference
VSX 6000 - Time Server down
I have such a problem: when I connect VSX 6000 to the Internet, it doesn't work. It is connected through the swith D-Link, total length of network cables is about 150 metres. Inside the diagnostik I see, that Time Server is red, i.e doesn't work. But IP Network lights green! IP adress is phisical, whithout proxy and firewalls.
I want to notice, that notebook, connected to the same LAN-port works whithout problems!
Polycom VSX 6000 (220022222001) Video Conference Logo
1320tn - network cable link light does not turn on. I have changed cables, turned off power, held down reset button and nothing works. Also, network config will not work when pressing in reset button. Regular configuration printout does not show any IP address. Could the network card have gone bad or the reset swith or possibly cable connection?
Take a breath, relax. The link light means that you have established a connection with whatever is at the other end of the network cable. You omitted that info. If the printer is connected to a switch, try a different port. If the printer is connected to a router and you have a free port, connect it there. If the printer is connected to a PC, that port could be bad. If you have another printer, try plugging it into the PC. As long as you don't have the handshake between PC and printer you won't see any IP address. I'm not familiar with the 1320. Saying that, I believe that the network interface is on the formatter board. And yes that could be bad. Doesn't the 1320 have a USB port? Have you tried that.
Before you spend any money, try connecting the printer to a different PC or a laptop. If it works, your printer is not the problem. If it still fails, call for service, because the formatter will need replacing.
Aug 06, 2011 | HP LaserJet 1320 Printer
after installing new hard drive i cannot fine how to connect to internet through wi fi
  1. Try pressing the Fn key and then the F2 key on your keyboard to turn on Wifi, the yellow Wifi symbol should light up on your laptop.
  2. Click the network icon in your system tray, this should display a list of available networks.
  3. If that doesn't work, then re-install the Drivers from the CD you were provided with when your received your laptop.
Jul 03, 2011 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
How do i use my built in wireless connection to connect to the internet,please.
make sure that your wireless or wifi light is on,you may try to press Fn and F2 at the same time to enable or swith on wireless..if wifi is already on,try going to start >> control panel >> network connections,go to wireless network connection and double click it, it will give you a list of wireless network,or right click and then "view available wireless network", if you get an error that windows cannot configure wireless connection,go to start >> all programs >> loo for either dell wlan utility or intel pro wireless, by opening that app,it will also search for wireless network in range,just double click on the network name where you want to connect and you sould be connected provided that "wireless network" doesnt have encryption like wpa or wep key..if your connecting to your home network,you should have wireless router at home and wireless is enabled on the router.
Oct 05, 2008 | Dell Inspiron E1705 Notebook
VSX 6000 - Time Server doesn't work
it is not able to resolve the IP address for the time server. I am having the same problem. If you enter in the IP address for the time server it will resolve your problem
Feb 12, 2008 | Polycom VSX 6000 (220022222001) Video...
1,267 people viewed this tip
Top Polycom Lands Phones Experts
Gerald Ridge
Gerald Ridge
Level 1 Expert
David Burbee
David Burbee
TEKUSER
TEKUSER
Are you a Polycom Lands Phone Expert? Answer questions, earn points and help others
