Tip & How-To about Office Equipment & Supplies
ERROR codesCanon 6030
Canon 6030 E000 Fuser did not heat up E001 Fuser temperature too high E002 Fuser temperature not rising at correct pace E003 Fuser temperature drops E004 SSR shorted E210 Lens home problem E212 Lens home problem E220 Exposure lamp problem E224 Blank shutter home problem E240 DC controller or composite power supply problem E400 Data communication problem E401 Pickup motor problem E402 Belt motor problem E403 Feeder motor E404 Delivery motor E411 Document detect sensor E500 Communication problem with copier E510 Feeder motor E530 Home sensor E531 Staple swing sensor problem E540 Bin shift motor rotation problem E541 Bin motor E710 DC controller E711 Document feeder IC failure E716 Cassette feed IC failure E800 Auto power-off circuit problem E901 Cassette feed motor E902 Paper guide home sensor problem
the canon ir2016 j displays E003 nd i know its fixing but i can't fix it what shall i do?
ferst solved[ astrix 2 8 astrix} servise mode athore ways replase fuser elament. E000 Fuser temp low. Heat lamp, thermoswitch, thermistor, SSR E001 Fuser temperature too high or shorted thermistor E002 Fuser temperature too low E003 Fuser temperature too low E004 SSR, or lamp reg. board E010 Drive problem E022 DV unit switching problem E030 Counter not working/open E202 Scan problem. Scan sensor, scan motor E204 Scan problem. Scan sensor, scan motor
Jan 18, 2010 | Canon iR 2016i Black and White Copier
286 people viewed this tip
k24674
jasbo
jasbo
