Tip & How-To about Office Equipment & Supplies
ERROR codes Canon 6012F
Canon 6012F C No problem. Means that the machine is correcting the fuser film tracking. CC Drum must be changed. Could be the drum serial number is identified by the logic as being non-compatible to that particular copier. E000 Low fuser temperature E001 High fuser temperature E002 High fuser temperature E003 Erratic fuser temperature E007 Fuser film off track and will not repair itself E010 Main drive problem E030 Counter problem E064 Scan problem, or power supply E202 Scan problem E210 Lens drive problem or lens sensor E220 Exposure lamp stays on or off E240 DC controller (main board) or composite power supply E261 Zero cross problem. Power frequency or composite power supply E400 Communication problem between boards E803 24 volt problem EO Fuser problem H Fuser overheat
How can I reset the copier canon NP 6412 shows the message CC on display?
CC means you will have to replaced your drum unit. The part number is F43-5411-700. About $150.00
There is a chip in the unit that records the number of copies run. You will either have to have the drum unit rebuilt and a new chip installed or just order in a new drum unit.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 19, 2010 | Office Equipment & Supplies
254 people viewed this tip
k24674
jasbo
jasbo
