Tip & How-To about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
How to check the version of windows 98/Xp/vista/windows7/server2000/server2003/server2008
Step 1: Go to start-> run and type winver
step 2: Done! you will get a window like this.There you can see all the details! Soluzia.net
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
slow running computer
there are many ways to increase the speed of your computer like old files.see the link to get step by step instructions http://soluzia.net/speedupurpc.php
Apr 21, 2010 | Microsoft Windows Vista Home Premium...
i have windows xp sp 3 i am trying to install hp laser 2055 appear fatal error and can not continue never i am trying alot but the same i uninstall sp3 and restart the same issue .
Unregister Windows Installer, and then reregister Windows Installer. To do this, follow these steps:
1. On the "Start" menu, click "Run:.
2. In the "Open" box, type "msiexec /unreg", and then press ENTER.
3. On the "Start" menu, click "Run".
4. In the "Open" box, type "msiexec /regserver", and then press ENTER.
Then restart and start installaion again ..ok it will work
Soluzia.net
Jan 12, 2010 | Computers & Internet
can not install Net Framewoek 3.0 because of
Sir,
Run the cleanup tool to clean out temporary files, run the .NET
Framework cleanup tool, Run the installation file, then reboot and try to install it again and see if it works. If not try the below following steps....
Step One:
1. Go to Add or Remove Programs, try to remove all .NET Framework.
2. Please download and install the Windows Installer Cleanup utility
from this link:
http://download.microsoft.com/downlo...BD/msicuu2.exe
3. Then, please run it from Start-> All Programs-> Windows Install
Clean Up.
4. Please remove all Microsoft .NET Framework shown there and click
Remove.
Step Two:
1. Click Start->Run, type INSTALLER and click OK.
2. In the open folder, click View menu and select Details.
3. Right-click the Date Modified column header.
4. Click Comments
5. In the Comments column, locate the cached Windows Installer file
that displays Microsoft .NET Framework 1.1 (English) RTL x86 enu.
6. Right-click the cached Windows Installer file and then click
Uninstall.
7. Close the window.
8. Delete the cached Windows Installer file.
Step Three:
1. Restart your computer.
2. While your computer is booting up, press F8 to invoke the startup
menu.
3. In the startup menu, choose Safe Mode.
4. Log on as an administrator.
Note: In Safe Mode, your system display and Desktop will look and
perform differently than in Normal Mode. This is only temporary.
5. Delete the folder C:\WINDOWS\Microsoft.NET
6. Delete the folder C:\WINDOWS\system32\URTTemp
7. In the C:\Windows\System32 folder, locate the file mscoree.dll.
Right click and rename it to mscoree.old
Step Four:
1. Click Start->Run, type REGEDIT and click OK.
2. Navigate to the following registry key by expanding the "+" beside
the registry tree in the left pane:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\.NETFramework
3. Delete this key in the left pane.
4. Repeat steps 2-3 to delete the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup
5. Restart your computer to Normal Mode
Step Five:
1. Please download the Microsoft .NET Framework Version 1.1
Redistributable Package from the following link and save it to C:
http://www.microsoft.com/downloads/d...DisplayLang=en
2. Click Start->Run, type "c:\dotnetfx.exe /C" (without quotation marks
and there is a space in this command) in the open box and click OK.
3. Click Run, and type "C:\.NET Framework 1.1" (without quotation
marks) in the open box click OK
Note: If you are prompted to create this folder, please click Yes to
continue.
4. Locate the folder C:\.NET Framework 1.1 and double click the file
netfx.msi in it to install .NET Framework components.
If .NET Framework 1.1 can be successfully installed, we can go on to
install .NET Framework 1.1 Service Pack 1:
Microsoft .NET Framework 1.1 Service Pack 1
Step Six:
If the above two can be installed correctly, please download KB886903
from the following link and install again:
http://www.microsoft.com/downloads/d...displaylang=en
If the problem still exists, please describe the error message when
installing Microsoft .Net Framework Service Pack in further detail
Thanks
Good luck
Nov 07, 2009 | Microsoft Computers & Internet
1,630 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
