Tip & How-To about Computers & Internet
Ailurus in Ubuntu
Ailurus is an Ubuntu enhancement application.
It can install/remove software which is outside official repository,
Helps to add/remove third party repositories and can change system settings.
Moreover, it help you study Linux skills.
Add Ailurus in Ubuntu:
(1.A)
Applications> Accessories> Terminal
When you open this copy it (when you ask for your password, type):
sudo add-apt-repository ppa:ailurus
Update the source list (Terminal):
sudo apt-get update
Install Ailurus (Terminal):
sudo apt-get install ailurus
(1.B) Run Ailurus
Applications-> System Tools> Ailurus
(1.C)
Ailurus was originally named as “Ubun-student“, and “Ubuntu easy setuper“.)
Computers & Internet Logo
HP Deskjet 1000 use with Linux operating systems
Question is old, but just in case:
installing HP printers in Ubuntu is very easy:
https://sites.google.com/site/tipsandtricksforubuntu/printer-info/hplip-driver
I am copying instructions here just in case site would go down:
  • open a terminal (Applications > Accessoiries > Terminal)
  • type the following command: sudo add-apt-repository ppa:hplip-isv/ppa
  • press Enter and if needed, type the required password
  • type the following command: sudo apt-get update
  • then type the following command: sudo apt-get install hplip
HPLIP is mentioned on official HP support pages as solution how to get HP printers working on linux.
Jan 19, 2012 | Office Equipment & Supplies
WHAT ARE THE ADVANTAGES OF UBUNTU USER:VISTA MICROSOFT OFFICE
Ubuntu is an open source operating system. With a Linux based system, there is no worry of gaining a virus, as well as all the security needed is built in from out of the box. With Microsoft Windows, you would need to worry about virus, hackers, etc. In a world where most of the security vulnerabilities are coming from third-party applications, Windows and Mac machines are at significant risk because they run lots of these apps and those apps aren't always updated automatically, which leaves the machines open to attacks. Again, to be clear, both Microsoft and Apple have comprehensive updating systems for their software - both the OS as well as company apps that run on top of the OS. The problem is with the software (programs, extensions, and plug-ins) from other vendors and the inconsistent methods they use for updating their code to protect against known flaws. With Ubuntu, there's one comprehensive software updating system. This is possible because Ubuntu has a centralized repository of applicationsand the only third-party applications that make it into the main repository are the ones that have been tested by Canonical (the company that produces Ubuntu) and are proven to work with the OS. This means that the Ubuntu main repository doesn't always have the very latest version of Firefox, for example, but you can be sure that the one it does have will typically install easy, work smoothly, and remain updated automatically. And, while iPhone and Android have a mix of free apps and paid apps, the apps in the Ubuntu Software Center are nearly all open source and free of charge. Like iPhone and Android, you have to sort through a fair amount of chaff in order to get to the wheat, but it's still a terrific 21st century computing experience. Both Windows and Mac need to learn from the app experience that is driving the mobile device market. Ubuntu has already beaten them to the punch.
If you add that to the fact that Ubuntu does a better job with software updates (a big security boost), then Ubuntu becomes a much more viable alternative for modern PC users, especially those who access most of their services and enterprise apps via a Web browser.
Jul 05, 2011 | Computers & Internet
i want to download music software but it wont let me
What you need to do is set your software repositories. Go into Synaptic Package Manager and select Repositories from the Settings Menu. In the Ubuntu Software tab, select all of the checkboxes under the "Downloadable from the Internet" heading. For good measure, you might also want to select all the checkboxes under the Third-Party Software tab as well. This should allow you to download more than just the purely open-source/GNU software that is usually enabled by default.
Oct 17, 2009 | Canonical Ltd. Ubuntu
Application 32 appears on the screen and the phone
This is because you have installed a third party application on your HH.Do hard reboot,connect to desktop manager and click on Application Loader ,delete all third party software.Use Application Loader to reinstall the applications on the handheld.Select the Erase Existing Applications option and dont install any third party software.
Jul 16, 2009 | RIM BlackBerry Pearl 8100
Ubuntu 8.04 Sound is Very Distorted HELP!!!
You need to add the following lines to /etc/apt/sources.list file or you need to make sure you have enabled Universe and multiverse repositories in /etc/apt/sources.list file
sudo gedit /etc/apt/sources.list
Make sure you have the following two lines save and exit your file
deb http://archive.ubuntu.com/ubuntu hardy universe multiverse
deb-src http://archive.ubuntu.com/ubuntu hardy universe multiverse
Now you need to run the following command to update the source list
sudo apt-get update
Install mplayer using the following command
sudo apt-get install mplayer
if you want to open mplayer just type
gmplayer
or
You can Open from Applications—>Sound&Video—> Mplayer Movie Player
Install libdvdcss2 and w32 video codecs in Ubuntu 8.04 (Hardy Heron)
Support for WMV, RealMedia and other formats has been bundled into the w32codecs package. This package is not available from the Ubuntu repositories due to licensing and legal restrictions.
For Ubuntu 8.04 (Hardy Heron) Users run the following command
sudo wget http://www.medibuntu.org/sources.list.d/hardy.list -O /etc/apt/sources.list.d/medibuntu.list
Then, add the GPG Key using the following commands
sudo apt-get update
sudo apt-get install medibuntu-keyring
sudo apt-get update
For i386 Users install Codecs using the following command
sudo apt-get install w32codecs libdvdcss2
For amd64 Users install Codecs using the following command
sudo apt-get install w64codecs libdvdcss2
Using above download locations you can install most of the mutimedia codecs for ubuntu.
Mplayer Plugin for Firefox
If you want to install Mplayer with plug-in for Mozilla Firefox run the following command
sudo apt-get install mozilla-mplayer
Apr 21, 2009 | Canonical Ltd. Ubuntu
324 people viewed this tip
David Payne
David Payne
