Tip & How-To about Office Equipment & Supplies
HP Office Jet All in One : Resetting Steps
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Semi-Full reset
  • Remove the ink cartridges.
  • Press and hold "#" and "6" button, while holding them both insert the power cable and release the button after 10 seconds.
  • Insert the ink cartridges.
NVM Reset
  • Press and hold "OK" and "Cancel" button, while holding them both insert the power cable and release the button after 10 seconds.
Regards,
Rizwan
hp office jet pro l7580 not display any thing on screen and can not use the power button to turn it off
Please try resetting the printer as per below instruction.
Power Drain:
Partial Reset
Semi-Full reset
Regards,
Riztech
May 29, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
the printer takes several minutes to print one page all ink cartridges are full and paper tray is full it just started doing this
Please try below two resets and let me know the performance.
Power Drain:
Partial Reset
Regards
Riztech
May 23, 2011 | HP Officejet 6500 Wireless All-in-One...
buttons dont work
Do you see any error messages in the LCD display?
Try resetting the printer as below
Power Drain:
Partial Reset
Semi-Full reset
May 22, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
The black does not print on alignment mode. I tried a new cartridge and it still doesn't work. The message is that the alignment failed and refer to documentation for details.
The printer needs reset, please try below resets.
Power Drain:
Partial Reset
Semi-Full reset
Regards
Riztech
Dec 18, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
printer displays error code 0x838a2200. Unable to reset; help!
Try below resets
Power Drain:
Partial Reset
Semi-Full reset
Oct 24, 2010 | HP PSC 2355 All-In-One InkJet Printer
866 people viewed this tip
k24674
jasbo
jasbo
