Tip & How-To about Televison & Video
How to program an rca universal remote without codes
If you have a universal remote but dont have the codes or the codes dont work then what you can try is to scan all the frequencys using the remote to manually scan to work for your telly or other equipment your trying to control.
Follow these simple instructions
1. Turn on the device you want the control to control ie the tv or dvd or stereo etc
2. You need to now press and hold the button for the device you want to control and also the power button untill the light on the remote stays on( for this case we are going to program it to control a tv) so press and hold the tv button and power button hold them down untill the light stays on
3. press the play button once every 5 seconds( a bank of 10 codes is being sent every time you press the play button)
4. when it turns the tv off wait press the rewind/reverse button and check it turns the telly back on if it does then you need to hold the stop button untill the light goes off.
Once you have done this check the remote is working properly ie changing channels ets if it dont work properly then follow the instructions again and try again you may need to do this a few times till it gets the right signal
Televison & Video Logo
need code for Sony DVD and Sony tv and how to program it I have ge 24991 1312 universal remote
Buy a SONY universal remote.
Most universal remotes do not support SONY, but a hand full do.
Packaging should explicitly state support for SONY.
Most IR remotes can use a carrier frequency range of 30-56KHz, with most using normally 38-40KHz, or likely the GE universal. SONY is in the mid 50KHz range, other manufactures in upper 40KHz range and audio equipment Bang & Olufsen and, Kenwood use a 455KHz frequency. The carrier is what your TV or DVD is tuned to see and the codes are transmitted like Morse code for digit ones and zeros to say, change channel or play.
Short to say if you don't find an auto code scan that works then try another manufacture. Manual can be found online at manualslib if lost.
Feb 27, 2015 | Sony Televison & Video
I have a universal remote control the code for my tv KLH brand is not listed. Is there a way to make the remote work with my tv?
hi do you have the manual for the remote or not if you have the manual then you can do a scan to scan all the frequencys to scan for your telly correct frequency.
If you dont have the manual then let me know ok
Feb 10, 2010 | Universal Remote Control Remote Control
i have lost the remote and im trying to program a universal remote to it but the codes arent working. Also the tv will not change channels. What codes do i use?
try the scan all / some tvs take a universal 4digit code/ but most old tvs are 3 digit and pound shop remotes are all 3 digit
look at book to scan all/dont enter a code when tv goes on or off press power button dep on remote
Nov 30, 2009 | Televison & Video
t.v and universal remote
i have a remote it is a rca and it is being used for a Daewoo tv.I need the code/model number rcr311
Dec 20, 2007 | Daewoo DTQ-20U4SC 20" TV
Frequency Code???
We bought a RCA universal remote and it did not work on the Durabrand. The Radio Shack 3 in 1 remote for $7.99 has the durabrand codes and we got it to work for us. Hope this helps.
Oct 24, 2007 | Durabrand DWT1304 13" TV
276 people viewed this tip
Top Televison & Video Experts
