Tip & How-To about Hardware & Accessories
Some may already have experienced the one mistake rule, and why Registry Cleaners are not forgiving with Registry deletion errors that YOU make. It's rarely the fault of the program. It's nearly always the user. There is no such thing as a safe Registry Cleaner, even in expert hands. A BOLD STATEMENT. I'm only concerned with the cleaning processes here, not the add-ons that most have these days. They scan your Hard Drive for various data that they are programed to add to the deletion notification screen, or clean without intervention after you set the parameters, then they clean the files away that you OK'd like a white tornado. A list of these files should pop-up and then it should ask you to confirm that each file is not required. Be extra wary of those that don't. Herein lies the problem. DO YOU KNOW EACH AND EVERY FILE ON YOUR PC? DO YOU KNOW EACH AND EVERY REGISTRY/SYSTEM FILE ON YOUR PC? Most Top rated Registry Cleaners also have a back-up utility to restore any files that you may have accidently deleted, and should ask you if you wish to back-up the Registry before proceeding. Fine you say. I'm saved !! WRONG!! Unless you do a full Back-up of your entire Hard Drive yourself, you run a definite risk that you may be staring at a blank screen for a long, long time. Hopefully your recovery disk will restore your system and save your other programs. Removing just one Core System file, regardless of the Cleaner's back-up, may make your system unbootable and unrecoverable. The obvious : - The Registry Cleaner's Back-Up is now useless. I'm only concerned with supposed Highly Rated cleaners here. The Low Rated ones are as useful as teeth on a duck, and as safe as Nitro-Glycerine on a trampoline. They have their uses, and used sparingly, and with quality cleaning programs and diligence, they may make your PC a tiny fraction better. Every few months, you should already be backing up your entire system regardless. This would be the ideal time to use a Registry Cleaner. If you're not prepared to back-up fully beforehand, don't clean. You simply need to ask yourself if it is worth the risk before you use them, and does my PC really need it. You may say "I've used these hundreds of times and never had a problem". You only need to make one mistake once. Personally, I like them, but they really are amongst the most "dangerous safe programs" out there..
Hardware & Accessories Logo
FIX REGISTRY
go to btjunky and download hirens boot software and put it on a cd,
it fixes most stuff on a computer in dos
Nov 24, 2010 | Computers & Internet
my coby lptop getting tto slow....why...
Most PC Problems like Slow PC performance is because the Windows Registry is corrupted or has critical errors. Try using a Windows Registry Cleaner to cleanup all errors. An optimized registry ensures error free and fast computing experience. Read more at www.fixpcfreeze.com
May 06, 2010 | Coby NBPC1022XPBLK Netbook
1,194 people viewed this tip
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
