Tip & How-To about Computers & Internet
REGISTRY CLEANERS - PROS AND CONS
Some may already have experienced the one mistake rule, and why Registry Cleaners are very unforgiving when You make a mistake, or get a bit lazy, or are too trusting.
There is no such thing as a safe Registry Cleaner, even in expert hands.
A BOLD STATEMENT.
I'm only concerned with the cleaning processes here, not the add-ons that most have these days.
They scan your Hard Drive for various data that they are programed to add to the deletion notification screen, or clean without intervention after you set the parameters, then they clean the files away like a white tornado.
A list of these files should pop-up and then it should ask you to confirm each file is not required. Be extra wary of those that don't. Herein lies the problem.
DO YOU KNOW EACH AND EVERY FILE ON YOUR PC?
DO YOU KNOW EACH AND EVERY REGISTRY/SYSTEM FILE ON YOUR PC?
Most Top rated Registry Cleaners also have a back-up utility to restore any files that you may have accidently deleted, and should ask you if you wish to back-up the Registry before proceeding. Fine you say. I'm saved !! WRONG!!
Unless you do a full Back-up of your entire Hard Drive yourself, you run a definite risk that you may be staring at a blank screen for a long, long time.
Removing just one Core System file, regardless of this Cleaner's back-up, may make your system unbootable and unrecoverable. The obvious : - The Registry Cleaner's Back-Up is now useless.
I'm only concerned with supposed Highly Rated cleaners here. The Low Rated ones are as useful as teeth on a duck, and as safe as Nitro-Glycerine on a trampoline.
They have their uses, and used sparingly, and with quality programs and diligence, they may make your PC a tiny fraction better.
Every few months, back up your entire system regardless. This would be the ideal time to use a Registry Cleaner. If you're not prepared to back-up fully, don't clean.
You simply need to ask yourself if it is worth the risk before using them, and does my PC really need it.
Personally, I like them, but they really are just too darn dangerous.
You only need to make one mistake once.
Computers & Internet Logo
I installed incredimail by mistake how do I delete it?
control panel, add remover programs select increadimail select uninstall
Mar 17, 2011 | Computers & Internet
Some may already have experienced the one mistake rule, and why Registry Cleaners are not forgiving with Registry deletion errors that YOU make. It's rarely the fault of the program. It's nearly always the user. There is no such thing as a safe Registry Cleaner, even in expert hands. A BOLD STATEMENT. I'm only concerned with the cleaning processes here, not the add-ons that most have these days. They scan your Hard Drive for various data that they are programed to add to the deletion notification screen, or clean without intervention after you set the parameters, then they clean the files away that you OK'd like a white tornado. A list of these files should pop-up and then it should ask you to confirm that each file is not required. Be extra wary of those that don't. Herein lies the problem. DO YOU KNOW EACH AND EVERY FILE ON YOUR PC? DO YOU KNOW EACH AND EVERY REGISTRY/SYSTEM FILE ON YOUR PC? Most Top rated Registry Cleaners also have a back-up utility to restore any files that you may have accidently deleted, and should ask you if you wish to back-up the Registry before proceeding. Fine you say. I'm saved !! WRONG!! Unless you do a full Back-up of your entire Hard Drive yourself, you run a definite risk that you may be staring at a blank screen for a long, long time. Hopefully your recovery disk will restore your system and save your other programs. Removing just one Core System file, regardless of the Cleaner's back-up, may make your system unbootable and unrecoverable. The obvious : - The Registry Cleaner's Back-Up is now useless. I'm only concerned with supposed Highly Rated cleaners here. The Low Rated ones are as useful as teeth on a duck, and as safe as Nitro-Glycerine on a trampoline. They have their uses, and used sparingly, and with quality cleaning programs and diligence, they may make your PC a tiny fraction better. Every few months, you should already be backing up your entire system regardless. This would be the ideal time to use a Registry Cleaner. If you're not prepared to back-up fully beforehand, don't clean. You simply need to ask yourself if it is worth the risk before you use them, and does my PC really need it. You may say "I've used these hundreds of times and never had a problem". You only need to make one mistake once. Personally, I like them, but they really are amongst the most "dangerous safe programs" out there..
Jan 18, 2010 | Hardware & Accessories
I installed Realtek Audio Codecs but it doesn't work even it's compatible with my os
By default, this Aspire 3000 supports only windows XP. Running something else, might cause trouble.
Acer Aspire 3000 XP Sound Driver download
If above doesn't work, start the notebook up in safe mode and uninstall any driver that has been installed already. Reboot. Download and install registry cleaners and driver cleanup tools (free ones) and repair the registry and clean it. Then re-try to install the driver above.
May 23, 2010 | Acer Aspire 3000 Notebook
my coby lptop getting tto slow....why...
Most PC Problems like Slow PC performance is because the Windows Registry is corrupted or has critical errors. Try using a Windows Registry Cleaner to cleanup all errors. An optimized registry ensures error free and fast computing experience. Read more at www.fixpcfreeze.com
May 06, 2010 | Coby NBPC1022XPBLK Netbook
My son's PC *always* needs to be booted twice to get it up in Windows XP Pro. For some reason it hangs during the first boot. Once it hangs you have to push'n'hold the power button to force shutdown, and reboot. It *always* boots successfully the second go. Any clues ..... I've already pulled it to bits, reseated the CPU/Memory/PCI cards with no joy.
You can do a bit of detective work and run MSCONFIG.EXE froma command prompt and go through that - particularly the boot, services and startup entries. The startup entries in particular - as from there you can select what is and what is started at startup - and a process of elimination can maybe help you track down the problem. 'Registry cleaners' may help - but often are more problematic themselves thn they are 'fixers'. You could edit the registry by hand, using regedit, but that is NOT recommended unless you really know what you are doing. Do note that if you change the start-up programs (i.e. change their enable state), you will get a warning at start-up that you are running a custom start-up using msconfig.
As a last resort, a fresh installation of Windows will fix things. Running a virus checker might also be a good idea.
Allan
Nov 03, 2009 | Computers & Internet
276 people viewed this tip
David Payne
David Payne
