Tip & How-To about Office Equipment & Supplies
ERROR codes Canon 4080
Canon 4080 E000 No fuser heat E001 High fuser temperature or shorter thermistor E002 Low temperature or bad thermistor E003 Fuser problem E004 Bad SSR (heat staying on) E010 Drive E020 Black toner motor E030 Counter E080 Interface problem with color unit E081 Vertical drive motor E082 Horizontal drive motor E083 Color unit sensor on right E084 Color unit sensor on left E085 Color unit release sensor or release or solonoid E086 Color unit claw release E089 Laser problem E100 Laser problem E110 Laser motor E140 Laser E202 Scan E203 Scan E204 Scan E210 Lens E223 Color unit filter drive motor E240 DC controller E401 RDF pickup motor E402 RDF belt motor E403 RDF feed motor E411 RDF document sensor E500 Sorter-Copier communication error E510 Sorter drive E512 Sorter driveE513 Sorter drive E514 Sorter drive E520 Top limit sensor or stack sensor E530 Sorter home sensor E531 Stapler home sensor E535 Stapler swing sensor E540 Stack shift sensor E660 IC card E710 DC controller E711 DC controller E714 DC controller E800 Power off circuit
the canon ir2016 j displays E003 nd i know its fixing but i can't fix it what shall i do?
ferst solved[ astrix 2 8 astrix} servise mode athore ways replase fuser elament. E000 Fuser temp low. Heat lamp, thermoswitch, thermistor, SSR E001 Fuser temperature too high or shorted thermistor E002 Fuser temperature too low E003 Fuser temperature too low E004 SSR, or lamp reg. board E010 Drive problem E022 DV unit switching problem E030 Counter not working/open E202 Scan problem. Scan sensor, scan motor E204 Scan problem. Scan sensor, scan motor
Jan 18, 2010 | Canon iR 2016i Black and White Copier
canon copier error message "error001"
"E000" Low fuser temp. (Heat lamp, thermoswitch, thermistor, SSR) "E001" High fuser temp. (Thermistor) "E002" Fuser temp. too low "E003" Fuser temp. too low "E004" SSR, Fuser temp too highchange thermistor in fuser
Aug 27, 2008 | Office Equipment & Supplies
544 people viewed this tip
jasbo
jasbo
