Tip & How-To about Office Equipment & Supplies
ERROR codes Canon 3225
Canon 3225 E000 Fuser problem E010 Drive E030 Counter E050 Duplex side to side problem E051 Duplex side to side problem E200 Scan problem E202 Scan return problem E204 Scan E210 Lens problem E220 Blank lamp open or lens home problem E240 Bad DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
i have a problem with the error e 051 some body help me
000 Fuser problem E010 Main motor, motor board, clock pulse E030 Counter E050 Duplex side to side problem E051 Crossway registration E200 Scan problem E200 Scan reverse sensor or scan E202 Scan return problem E204 Document sensor, scan reverse sensor or scale E210 Lens problem E220 Lens E220 Blank lamp open or lens home problem E240 DC controller E400 Document feeder board problem or document feeder interface problem E500 Sorter E620 Editing problem
Jan 15, 2010 | Canon imageRUNNER 400S Copier
Have an error code on Imagerunner 105 of E0005f2-001. Anyone know what it is and/or how to resolve. Thanks!
E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire E002 Fuser temperature not rising at correct pace, same possibilities as E000 E003 Fuser temperature drops. Same as E000 E004 Fuser problem: AC driver, SSR bad, wire shorted E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this E006 Fuser feed connector E010 Drive problem. Main motor, gears, etc E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller E030 Total counter E031 Option counter or total counter E050 Holding tray (duplex) home position sensor motor or board E051 Holding tray (duplex) home sensor motor or board E202 Panel locked up, but might be no Код ошибки, scan motor problem E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor E402 RDF belt motor or pulse sensor E403 RDF feed motor or pulse sensor E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motor E522 Sorter push bar motor
Jan 13, 2010 | Canon imageRUNNER 105 Copier
380 people viewed this tip
jasbo
jasbo
