Tip & How-To about Office Equipment & Supplies
How to use a printer?
Install a New Printer DIY installation of your new printer in Windows. You may have a new printer with an installation disc, or maybe a second hand one with no disc. Either way you will find out how to install your printer onto your computer.
Add Network Printer If you have two or more computers in your house or office you will only need one printer installed on one computer for both to have printing privileges. This article shows you how to add a network printer to Windows Vista.
Add Network Printer Applies to Windows XP. Even though the instructions are similar to installing a network printer on Windows Vista, there are a few extra tips that might be interesting.
Enable Printer and File sharing How to enable in Windows XP And Vista. If you want to share a printer on your network you must enable printer sharing. It is not hard to do but it will not work if it is not enabled.
Path to your network printer How to find the path \\server\printer. If Windows does not find your network printer automatically then you will need to know the path to your network printer.
Set Network printer permissions Set who can change printer settings in Windows XP and Vista. I personally like to let everyone on the network just print and not be able to change too many settings to do with the printer.
Network printer has problems printing - You do not have permission to use selected printer.
Quick Printing Trick Cool printing trick for Windows Vista and XP.
want to install printer
If you are running Windows XP or Windows Vista, you may simply plug in the printer to the computer, and the computer will install the generic driver.
By default, Windows XP and Vista already has the generic driver installed.
However, if the printer is not a Plug-n-Play device, you will need to load the CD that came with the printer, and follow the installation wizard.
Thank you and good luck!
Jun 13, 2010 | Brother MFC 240C All-In-One InkJet Printer
I install Kodak ESP 3250 all N one print computer wont connect Is
we to were unadle to install such a printer ,customer services usless .they blamed or computer & os our's must be a different copy of windows 7 to everybody elses!!
Apr 10, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
new computer printer does not install
best site for Lexmark printer drivers
http://www.printcountry.com/drivers/LEXMARK_DRIVERS.asp
for how to install a printer in a computer
How to load a printer on a pc step by step instructions
http://freepctech.com/pc/xp/xp00168.shtml
http://kb.iu.edu/data/aksl.html
Installing a printer on a Windows 95/98 network
INSTALL THE PRINTER on a PC
ENABLE PRINTER SHARING
MARK the NEW PRINTER as a "Sharable" Printer
INSTALL THE PRINTER ON THE OTHER PCs
Troubleshooting Windows 95/98 networking problems
http://www.mcgill.ca/ncs/products/soho/networking/printer/
How to install a printer driver locally for a remote printer in Windows XP/ Windows 2000-
http://support.microsoft.com/kb/282842
Dec 18, 2008 | Lexmark Office Equipment & Supplies
cant get my printer to install
all this links will help u
Dec 15, 2008 | HP Office Equipment & Supplies
add printer without a disk.
Windows should detect any new hardware plugged into the system and allow your to begin to install. Connect printer cable to your computer. Then plug printer to power and turn it on. Windows should detect the new hardware and let you install. If it finds your printer click on the pop-up box at the lower right corner of your monitor to begin install. If it cannot find the driver follow instructions below:
type in model (ie., hp psc1210v) of your printer in your browser search engine followed by the word 'driver'.you should be able to locate a place to download the driver. Install the driver, connect printer and turn the power on. windows should find new hardware and proceed to install.
Sep 21, 2008 | Lexmark Office Equipment & Supplies
229 people viewed this tip
jasbo
jasbo
