Tip & How-To about Televison & Video
Fixing the glass on cracked screens.. LCD or Plasma
Ok, now this tip is a bit out-there bt.. here goes.. I have found this to actually work... well, infact. With limitations.
We have all heard or seen the "Wii Screen".. lol Where the user of the Wii controller.. dosen't, control it, I mean.. no they let go, it slips out of thier hand and shazam.. ya got a busted TV screen.
OK well there is a repair that will sorta fix and maybe even make it watchable, but ONLY if it isn't too big and hasn't actually cracked the Element behind.
Get in touch with one of theose car windscreen repairers, you know the ones that fix cracks in auto windows, and are "optically difficult to detect" sic.
Well if ya can persuade the dude doing it that Car.... TV ....wats the difference, still Glass, then ya just might get an acceptable Crack Fix depending.. but it is worth a try.. it does work..
Televison & Video Logo
my lenovo laptop g585 is not starting..it was on in proper working condition,i ws working on it,bt suddenly 10mins after i came,i found it locked as it usually gets when it is inactive for 10mins,bt a
OK RITA
Try this :
unplug you computer
remove the battery
with no battery and no power cord inserted , press down the power button for 30 seconds then realese
reinsert the battery
plug the computer back to the power cord
now press the power button
let me now if this helped
hope this worked for you
Dec 18, 2013 | Computers & Internet
After a few minutes of use, my WESD51 read out goes up to 902F but the tip is actually very cool (like 350F - 400F). If I put a load on the tip, it straightens out for a while, goes back to the set temp. then does it again in a few minutes. My station is less that two months old.
I was searching this and accidentally found the answer. Just for future reference, the issue with mine was the contacts between the station and the tip, where you have to lock it. Wiggling it would get rid of the error, so I looked at the contacts (the pins that go into it) and sure enough they were mildly corroded. I brushed them off a little bit and it worked fine. If I get a new tip, I'd look into something that prevents rust, possibly WD-40, to prolong the life.
Sep 04, 2011 | Weller Wesd51 Digital Soldering Iron...
how to make geforce6100pm-m2 read both memory slots
make sure your memory meets these guide lines.
? 2 x 240-pin DDR2 DIMM socket support up to 16 GB*
? * (Due to the DRAM maximum size is 2GB at present, the memory maximum size we have tested is 4GB)
? Dual-channel DDR2 memory architecture
? Support DDR2 800/667/533/400 DDR2 SDRAM
Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows?32-bit OS.
For Windows?64-bit OS with 64-bit CPU, there is no such limitation
which means win xp will only read 2gig and win vist/7 will read 4g so if you have 2x 2gig and only 1 is registering its working fine with win xp.
Jan 31, 2011 | EliteGroup GeForce6100PM-M2 Motherboard
Acer Aspire 9410 Won't work with two memory slots filled
As you mentioned that you want to use Maximum memory that is supported by 9410, I would like to tell you that you have 32 bit processor in your notebook as its not always advisable to use 4 GB RAM with 32 bit processor as we have seen lots of compatibility issues.Infact in 32 bit processor windows will typically report only 3.2 GB due to a limitation of windows itself.
Mar 25, 2009 | Acer Aspire 9410-4317 Notebook
236 people viewed this tip
Top Televison & Video Experts
Electro Med Services...
