Tip & How-To about Computers & Internet
Access software setup shipped with HP PC after Retail OS Installation
Scenario: You have installed a Retail Operating System but have left the recovery partition (usually D drive) on your HP Desktop PC and you want to access the original softwares shipped with the PC.
Tip:
1. Click start, run. Clear contents of run box.
2. In run box, type "D:\hp\apps" without quotes and hit ok.
3. This will open a folder that would show couple of folders. These are the applications shipped with your PC. You can identify the software you need. In that folder, open SRC folder. You will find setup for the application here. Install the application from here.
Computers & Internet Logo
F11...system recovery in hp laptop
System recovery is for serious disk/operating system corruption problems. There is a system recovery partition on HP laptops that contains routines to restore your laptop to the configuration it came from the factory with. Backup all your personal files to a CD or USB stick or portable hard drive before using system recovery as it will erase anything you have added to your primary hard drive since it left the factory. That can especially be a problem if you have upgraded to a newer version of Windows than what your laptop came with, as HP is somewhat 'known' for not upgrading the recovery partition if you don't have recovery CD's for the new operating system bought from HP. If your recovery partition has been erased or corrupted, you will have to either use HP recovery CD's (which may be available from HP if your laptop is new enough)
or do a format and complete installation from the proper Windows installation CD. Either way, your personal files are toast if you don't back them up first. In some cases of operating system failure, you can get an external USB drive box, put your old HDD in it and use another computer to try and read files from the disk to try and save your personal files.
Jul 23, 2014 | Computers & Internet
My computer is saying that the system is not fully installed and all I want to do is to resite it to its factory settings
Which operating system ?????.....
The HP Recovery Partition that comes pre-installed on most new HPs is like built-in insurance if your system becomes unstable or fails.
If the problem is severe enough, you may not be able to start the HP Desktop Recovery Manager from Windows but you can start it manually by following the steps below.
Disconnect all peripheral devices and power on the computer.
Press the F11 key after the computer first powers on to start the HP Recovery Manager.
Follow the on-screen instructions to back up recoverable files on the hard drive to an external drive or media.
Continue following the instructions to recover the hard drive to its original factory condition.
Click "Finish" when the recovery is complete.
Reconnect devices and reboot the computer.
Reinstall software and update Windows and HP to current settings.
Performing an HP System Recovery (Windows Vista)
HP Pavilion Recovery Partition
Accessing the recovery partition on your HP Pavilion laptop allows you to restore your computer to speed it up, eliminate a virus or repair your Windows operating system.
The Recovery Manager program makes it possible to restore your laptop to its settings as of a previous date or restore your computer to its original factory settings, which will erase all of your installed programs and personal data.
Using the recovery partition allows you to bypass the hassle of keeping track of recovery discs, which could be damaged in storage, rendering them useless when you need them.
Turn on or restart your HP Pavilion laptop.
Press "F11" when the "Press <F11> for recovery" message appears during the HP Pavilion boot process.
Select "Recovery Manager" from your list of recovery options and press "Enter."
The Recovery Manger program will open on your screen, and you can begin the recovery process.
Access Recovery Manager Within Windows
Click the "Start" icon or "Start" button in the lower left corner of your Windows home screen.
Click "All Programs" and then "Recovery Manager."
Click "Recovery Manager" again to open the Recovery Manager program on your HP Pavilion laptop.
using the hp recovery manager in windows 7
Oct 15, 2013 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
how to reset
Which operating system ??..
or
While restarting the computer keep tapping on the F10 key
on the next screen you will find start system recovery , and on the next screen you will find advanced options
in advanced option you will find an option for Destructive Recovery.. click that
If you are not able to run the recovery on the computer as above then you will need no use a set of recovery cds..... if you dont have them you can get it from HP..
or
HP Desktop factory settings
replaced motherboard &hard drive in hp pavilion, now it will not recognize reovery cd
By replacing the Hard drive you have removed the recovery partition with the operating system on it.
Did you make a backup of the Operating system to a set of CD's or just the Data?
If it was just the data you need a new operating system through HP Tech Support. The instructions are here
EmptyPortlet
Feb 13, 2013 | HP Pavilion Slimline S3020N PC Desktop
windows not installing
Sir please specify the Operating system which you want to install.
You can perform the following troubleshooting steps.
1) Your computer comes with a preinstalled operating system. The model also have recovery partition ( mostly in your D: drive) for installing Genuine Windows Vista Home Premium. You can use this recovery partition to install the operating system...
2) If you have created Recovery disks from the recovery partition then you can install the operating system from those disks.
3) If you have deleted the recovery partition and your recovery disks are damaged, then if your Notebook is under warranty , you can get recovery disks from HP with out any cost( FREE).
For more information contact HP 24X7 chat support.
For drivers you can visit the following HP link and select the operating system and download the drivers...
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3545112&lc=en&cc=us&dlc=en&lang=en&cc=us
http://welcome.hp.com/country/us/en/contact/chat_1.html
Jun 30, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
148 people viewed this tip
David Payne
David Payne
