Tip & How-To about Computers & Internet
Alternate method to access Application Recovery/Recovery Manager in HP PC
Scenario: Recovery manager or Application Recovery on your HP Desktop PC doesn't work or you are unable to access Application Recovery or Recovery manager.
Tip:
For Application Recovery:
1. Click start, my computer.
2. Open C: and Windows Folder.
3. Open SMINST folder within Windows folder.
4. Double click appinst.exe to open application recovery.
For Recovery Manager:
4. Double click restore7.exe to open Recovery Manager.
If above folder is not found. Then,
1. Click start, run. Clear contents of run box.
2. In run box, type "D:\hp\apps" without quotes and hit ok.
3. This will open a folder that would show couple of folders. These are the applications shipped with your PC. You can identify the software you need. In that folder, open SRC folder. You will find setup for the application here. Install the application from here.
Computers & Internet Logo
My computer is saying that the system is not fully installed and all I want to do is to resite it to its factory settings
Which operating system ?????.....
The HP Recovery Partition that comes pre-installed on most new HPs is like built-in insurance if your system becomes unstable or fails.
If the problem is severe enough, you may not be able to start the HP Desktop Recovery Manager from Windows but you can start it manually by following the steps below.
Disconnect all peripheral devices and power on the computer.
Press the F11 key after the computer first powers on to start the HP Recovery Manager.
Follow the on-screen instructions to back up recoverable files on the hard drive to an external drive or media.
Continue following the instructions to recover the hard drive to its original factory condition.
Click "Finish" when the recovery is complete.
Reconnect devices and reboot the computer.
Reinstall software and update Windows and HP to current settings.
Performing an HP System Recovery (Windows Vista)
HP Pavilion Recovery Partition
Accessing the recovery partition on your HP Pavilion laptop allows you to restore your computer to speed it up, eliminate a virus or repair your Windows operating system.
The Recovery Manager program makes it possible to restore your laptop to its settings as of a previous date or restore your computer to its original factory settings, which will erase all of your installed programs and personal data.
Using the recovery partition allows you to bypass the hassle of keeping track of recovery discs, which could be damaged in storage, rendering them useless when you need them.
Turn on or restart your HP Pavilion laptop.
Press "F11" when the "Press <F11> for recovery" message appears during the HP Pavilion boot process.
Select "Recovery Manager" from your list of recovery options and press "Enter."
The Recovery Manger program will open on your screen, and you can begin the recovery process.
Access Recovery Manager Within Windows
Click the "Start" icon or "Start" button in the lower left corner of your Windows home screen.
Click "All Programs" and then "Recovery Manager."
Click "Recovery Manager" again to open the Recovery Manager program on your HP Pavilion laptop.
using the hp recovery manager in windows 7
Oct 15, 2013 | HP Pavilion 524w (DB280AR#ABA) PC Desktop
how to reset
Which operating system ??..
or
While restarting the computer keep tapping on the F10 key
on the next screen you will find start system recovery , and on the next screen you will find advanced options
in advanced option you will find an option for Destructive Recovery.. click that
If you are not able to run the recovery on the computer as above then you will need no use a set of recovery cds..... if you dont have them you can get it from HP..
or
HP Desktop factory settings
my webcam does not work on my acer netbook. How
Check whether the Webcam is listed in Device manager Go to Start right click on computer click on manage , click on Device manager , In Device manager under imaging devices see whether there is webcam listed , if not install the webcam driver from www.support.acer.com, Check whether the Webcam Application is listed in All programs, if not Re-Install the Software from Acer Recovery manager Access Recovery Manager by going to All Programs ->Acer-> Acer Recovery manager -> Restore-> Restore Drivers and Applications , Select webcam software to Install
Jul 13, 2010 | Acer Aspire One Netbook 8.9" Notebook
Hp Webcam
If your Notebook is installed with Vista, there is no option to start the Webcam directly without using any application.
However, you can try using the HP Webcam drivers which are for XP with which you will get a Preview window to use the webcam without using any application like Messengers etc..:
Download the above mentioned driver from the link below :
ftp://ftp.hp.com/pub/softpaq/sp35001-35500/sp35414.exe
Save the file in the Notebook and double click once the file is saved to install the drivers.
However, if you are unable to access the webcam using Quickplay application, I recommend you to try reinstalling the application by following the instructions below if the Recovery Partition is available and you are able to use the Recovery Manager application :
Click on Start and then on Control Panel in the window that appears, click on Classic View in the left pane.
Now, among the icons that are displayed, double click on Programs and Features icon and among the list that is displayed, click on HP Quickplay and click on Uninstall button on the top.
Now, follow the instructions available in the link below to reinstall Quickplay using Recovery Manager :
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&docname=c00834921&dlc=en&lc=en&jumpid=reg_R1002_USEN
You can also try downloading Cyberlink YouCam application which is provided for all latest Notebooks to access Webcam from the link below :
ftp://ftp.hp.com/pub/softpaq/sp39001-39500/sp39372.exe
Save the file into the Notebook and double click the file to install the application.
You can find the required instructions to use Cyberlink YouCam application to access the webcam of your notebook from the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01414839&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Additionally, you can find the details about YouCam application from the link below :
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01415015&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Hope the information helps...
Nov 19, 2008 | HP Pavilion dv6000z Notebook
480 people viewed this tip
David Payne
David Payne
