Tip for Spectra JBP78 Electric Kitchen Range
Replacing a Glass Cook Top
posted on Feb 11, 2008
jsrock516
jsrock516
Rank: Guru
Rating: 96%, 7527 votes
This advice is for Electric Ranges equipped with glass smooth tops. If it becomes necessary to replace the cook top due to wear or damage, here's some helpful tips on how to complete the repairs yourself. NOTE: Cook tops are NOT cheap. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most warranties DO NOT cover cosmetics. That is, if your cooktop paint starts to wear off, most manufacturers will not replace it. Warranties also DO NOT cover accidents such as dropping something on the top and breaking it. Warranties DO cover blistering, warping and heat related breakage (if you are using the recommended cookware). This is why it is important to follow all the manufacturer's use and care instructions that come with your range. I know this does not include ALL manufacturers, but this is true with most.
This is a recommended two-person repair job. Please read through the instructions carefully before starting the repairs, and follow any safety recommendations.
1. UNPLUG the range before servicing. There are dangerous voltages still present even with burners turned off.
2. If the old cook top is broken, you will need to get rid of a much of the glass shards as you can and thoroughly vacuum the area around the oven box. Use extreme care when handling broken glass. Wear safety glasses and gloves.
3. There are a few screws located under the front edge of the cook top. You will need to open the oven door to see them. Remove these screws and the top should lift up. If the range is not equipped with any kind of hinge supports, the top will have to be propped up.
4.On some ranges, there is a disconnect plug for the surface element wiring harness. If you have this feature, Follow these steps:
  1. Unplug the cook top and leave the elements in place.
  2. Place the whole cook top assembly face-down on a soft surface (like some old towels, or a blanket).
  3. Remove the surface element assembly leaving all the elements wired together.
  4. Place the new cook top face down in the same manner and lay the surface element with wiring harness directly on to it and screw in place.
  5. Install the new cook top back on the range and you are DONE.
5. If the wiring harness does NOT unplug, follow these steps:
  1. There are a series of screws holding the element assemblies in place. Leave these assemblies wired together for ease of replacing. It is recommended that a second person holds the assemblies in place to support the wires until all the screws have been removed.
  2. Lay the intact element assembly, with wires still connected, on top of the oven box. Handle the surface elements with care. They are very fragile. Care also must be taken not to handle the element coils or ceramic material. Try to handle from the underside of the element only. Oil from your hands can cause damage to the element and/or premature failure.
  3. If you have to remove the elements, individually, make sure you write down how the wires were connected to ensure you reconnect them in the right order. Make sure you also take note of the numbering scheme on the element and make sure you place the mounting brackets in the same holes that they came out of. Use care when screwing into the new cook top. CAUTION: The screw holes are usually painted and a little force may be required to thread the screws. Do not apply too much pressure on the glass, or you can damage it.
  4. Prop the new cook top in place and install the surface element assembly from underneath. A helpful hint: Use some duct tape to hold the assembly until you have screwed it back into place. Don't forget to remove the duct tape when completed.
  5. Lower the new cook top into place and secure with screws.
    Good luck and I hope this helps.
Very Helpful
Was this helpful?
Yes
No
17 people thought this was helpful
Comments
- Oct 17, 2009
For anyone as frustrated as I was that has to fix their glass top, read this and do exactly as it says! It will save you hundreds of dollars!
I am the opposite of a handyman - in fact, the proof is in the fact that I have to fix my oven at all.. I was trying to install a shelf/pot rack above the oven, and because I don't at all know what I'm doing, I stepped on my range's ceramic glass top for support thinking it was as strong as my counter and my step stool. NOPE, foot went right through it, and I didn't stop swearing at myself for 24 hours. I found this website, and a few others but none as helpful and exactly accurate as this one. I ordered my part for my Maytag Gemini double oven (cost me $189 + tax), and followed this site's instructions step by step.. It only took me 40 minutes by myself, even though it recommends two people (it would have gone twice as fast, I had to prop the oven top up with some cups while I undid screws.. not recommended.)
Just tested my oven a few minutes ago, works beautifully and looks beautiful!!
Thanks so much to the original poster!!!
- May 03, 2009
Can you please show me where to order the smooth cook top glass? My range is Wirlpool WERP4120SQ0,
Thank you
Add a Comment
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
Can you Help with these Kitchen Ranges problems?
Answer
the oven temperature will maintain an accurate temperature
Answer
i have no control over the temperature of the left 2 burner they are always on high
Answer
I ordered a new baking element for my GE Spectra Model JBP78 oven. I need to know how to install the... (More)
Answer
the glass shattered on the door while self cleaning. is this a know problem?i
Answer
oven won't get hot, burners won't get hot, lights/clock all work
Describe your problem:
Select a Category:
Insert Link
Insert Image
Insert List
Insert List
Spell Check
What is this?
Select
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Range & Oven Repairmen
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
(800) 555-9987
All the services you need in order to get your...
Home Blue
