Tip & How-To about Hotpoint TDC32 Electric Dryer
Common faults on a hotpoint tdc32
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuitboards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also bethe fault.
For Free Video help on yourHotpoint TDC32 Tumble Dryer USE THIS LINK
Hotpoint TDC32 Electric Dryer Logo
will not heat
Common faults -
1 The heating elements can fail (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuit boards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also be the fault.
You-Tube video "Vx9JMZRRKrg" placeholder
Jan 08, 2010 | Estate Dryers
no hot air
Common faults -
You-Tube video "Vx9JMZRRKrg" placeholder (do not delete)
We have a full video library on appliance repair video’s
Jan 07, 2010 | Dryers
not heating
Common faults -
You-Tube video "oYErKqR3LsY" placeholder (do not delete)
DRYER RUNS WILL NOT HEAT AND TIMER WILL NOT MOVE
This sounds like the timer is the fault but check these Common faults -
Inglis IS8200 Dryer not producing heat.
Common faults -
You-Tube video "75l_AtpGkks" placeholder (do not delete)
Jan 02, 2010 | Dryers
1,280 people viewed this tip
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
