Tip & How-To about Whirlpool ER6AHKXPQ Top Freezer Refrigerator
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
Whirlpool ER6AHKXPQ Top Freezer Refrigerator Logo
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other problem and no build up of ice anywhere. I tried changing the humidity settings - nothing happened. There is no water on the floor..... and freezer working fine. Door is not opened very much as I live alone. Any suggestions>
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
refrigerator is freezing everything top to bottom wondering if there is an air filter that I could clean as we have had some drywall done recently and thought maybe something is restricting air flow.
Apr 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
we have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
Mar 14, 2009 | Bosch Refrigerators
freezer not freezing food and fridge not staying cold enough
Check the compressor with a volt meter, if the compressor is getting proper voltage then check the relay. But this sounds like a problem with the compressor
Feb 12, 2009 | Whirlpool GB9SHKXL Bottom Freezer...
Fridge not cold
my freezer is over freezing and my fridge is not cold. I have a whirlpool where the freezer is on top and the fridge is on the bottom. I need guidence in trying to figure out the problem.
Sep 29, 2008 | Kenmore 64802 Top Freezer Refrigerator
2,961 people viewed this tip
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
