Tip & How-To about Computers & Internet
Troubleshooting 101
Fix common PC problems Having trouble with your computer? You've come to the right place. Even if you don't know a computer language (or want to), you can solve several common PC problems on your own.
F1 is magic: Get help on your PCIf you can’t figure out how to complete a particular task in your software program—and you’re using a PC—the most important shortcut to know is the F1 key. Just push it while the program—Word, Excel, or whichever program you’re using—is open and active, wait a moment, and the Help window specific to your active program will appear. The F1 key works with almost all Microsoft products, so it’s a helpful starting point for a wide variety of problems.
In this article, we offer many ways to do what you need to do in Windows 7 and Windows Vista. Often, there may not be a Help topic for Windows XP, but the process is often the same as in Windows 7 or Windows Vista. The only difference is usually where to find the link in Control Panel. Most often, it’s just a matter of slightly different wording in the heading or the text describing the task. Don’t worry. If you search in Control Panel, you’ll usually find the link you need.
The basicsIf you’re encountering a different kind of obstacle – your new device won’t appear on your desktop, an application you added won’t run, or your computer is refusing to start up – here are a couple of preliminary steps:
  1. Before adding any major hardware or software to your system, make sure you've recently backed up your Windows 7-based PC or your Windows Vista-based PC as a safeguard. By using the automatic backup functions, you can schedule regular upkeep for maximum convenience.
  2. Write down the contact information for Microsoft Customer Service and Support, should you need to consult an expert. Take a second to print the below instructions as well, and keep them handy as you walk through the troubleshooting process.
  3. Many issues can be resolved by simply checking to be sure that all of your plugs are connected properly. After you are sure of that, try restarting (“rebooting”) your system. Turn your computer off, and then back on a few seconds later. If the problem continues, follow the steps below.
Locating the problem Ask yourself if the problem is related to hardware, software, or the operating system (such as Windows 7, Windows XP, or Windows Vista). The following are some common indicators that can help you decide which is the right answer.
If you're uncertain, don't worry. Just start at the top by determining if your software is working, using the Software errors section that follows. If the issue persists, proceed to the Hardware trouble section and then to the System failure section.
You can also find really helpful information at Microsoft Help and Support. If you'd like to search by individual program, try the Product Solution Center. Or check the columns and blogs found on the Windows Community Web site, where you can find helpful input from experts and fellow computer users.
The lists on the right side of this page may also help you narrow down the type of trouble you are experiencing.
Software errorsIf programs refuse to install, won't appear on your desktop, can't seem to run without freezing, don't load at a decent speed or function properly, or Internet access is unavailable, here's how to troubleshoot:
General issues
  1. Confirm that your PC meets the software's minimum system requirements. If it doesn't, you'll be unable to run the program without upgrading your computer's hardware. Note that PCs which barely meet or just slightly exceed these minimums may run the software more slowly and can be less reliable. Windows 7 and Windows Vista users can reference the Windows Experience Index to quickly gauge their PC's general capabilities.
  2. Check for compatibility with Windows 7 and Windows Vista.
  3. Close open programs and windows that you're not currently using. These can eat up system memory and processing power, slowing your PC or preventing additional software from running. Try running the program again.
  4. Check available hard drive space. Roughly 5 to 10 percent of your hard drive's total storage allotment should be left free to ensure optimum system performance in Windows 7 and Windows Vista, prevent crashes, and keep Windows running at top speed.
    Note Use Disk Cleanup to free more space:
    Windows 7
    Windows Vista
    Windows XP
    Check for program updates and information on frequently encountered issues at the software manufacturer's Web site. For Microsoft products, you can also load Windows Update for Windows 7, Windows Update for Windows Vista, or visit the Microsoft Download Center. If you install an update, restart your computer, and attempt to run the program again.
  5. Uninstall or delete unwanted programs in Windows 7 or Windows Vista to cut down on clutter and remove any drain on your system's resources.
  6. Disable programs you don't use to in Windows 7 or Windows Vista by preventing them from automatically loading when Windows starts. If you’re running Windows 7, restart your computer, and try the program again.
  7. Defragment your hard drive in Windows 7 or Windows Vista to improve performance.
  8. Scan for viruses and spyware. Windows Defender in Windows 7 and Windows Vista can help detect and prevent threats, along with preventing annoying pop-up notices and unauthorized home network intrusions. You can scan your PC for free.
  9. Reboot your computer and try loading the program again. If it still won't load or work correctly, you may need to uninstall the software and then reinstall it from scratch and reboot again. Advanced users can also try these advanced troubleshooting tricks in Windows 7 and Windows Vista.
  10. Consult Microsoft Help and Support and the Windows Community. If live assistance is required, first contact the software manufacturer's customer support department. For additional assistance, try Microsoft Customer Service and Support.
Computers & Internet Logo
whilst setting up my phone I've pressed German instead of English for the language and don't know how to put it righte
Go to phone settings and select the option display. You can find the the settings for language there you can choose your language.
OR:
you can find in the settings>>phone settings>>language.
hope this helps.
if you need, and you don't have copy of the manual, let me know
Aug 12, 2012 | Cell Phones
Within a specific department I've created, I've added several categories. I know how to add items to departments but I am having trouble adding items to the specific categories. What steps do
You have the order backwards. Top order is categories such as FOOD or LIQUOR. Then comes Departments such as APPETIZERS, ENTREES, DESSERT. Then items like RIBEYE STEAK, BAKED POTATO, SALAD. And categories are entirely optional. They only come into play if needed to group departments on certain reports. They don't display, just departments and items.
sysadmin@ccybernet.com
Please return and give me a favorable rating if this helps or is of value to you.
Feel free to email me with more details if need be.
Jun 07, 2012 | Pc America Restaurant Pro Express
i always got a Error #2046 on zwinky and i cant play it please help me
There exist many reasons for running into various error messages on your computer; if you've noticed an access runtime error 2046 in recent days, don't despair. You must realize that the lion's share of pc problems may promptly be sorted out although you may lack advanced computer skills. Scan the following few paragraphs and i will explain a quick and effective way to solve this error message problem.
Before you start, it's of great importance that you figure out the root of these problems. With a lot of these occurrences, your windows registry turns out to be involved - this is the location where windows keeps track of your activity. It keeps all records of the programs and hardware you've added, not to mention the links to the files that operate these applications. It is often the case that a broken link or damaged registry can be the reason for an access runtime error 2046 and a variety of other troubles, which can include slow response, lock-ups, and .dll errors.
Several other factors in getting runtime errors are the improper loading or removal of software programs, errors which can be caused by having many different applications on your pc, infections with viruses and spyware, etc. Once more, all of these factors can cause missing or damaged links in your windows registry, thus leading your windows to display all of those troublesome error alerts, or even worse problems
You can solve these problems in a number of different ways; the hard part is that you don't always know which specific program(s), or which specific corrupted registry configuration(s) may be the reason for the problems. In this scenario, particularly if you are not proficient in computer technology, you can choose from two possibilities: take the expensive route and hire a computer specialist, or simply download a specialized registry cleaner.
A registry cleaner is a tool that automatically scans your pc and finds a multitude of abnormalities common in personal computers; the tool does more than just detect these problems, it automatically takes care of the problem and restores your computer to its maximum efficiency. So the next time you encounter an access runtime error 2046, it is recommended to download one of these tools, many out there provide free computer scans and a limited number of free fixes. Now's your chance to eliminate this difficulty with just a few minutes of your time.
Sep 03, 2011 | Dell Dimension C521 PC Desktop
I've been having trouble with my 95 Deville. It stalls when l'm on the road sometimes and now I can't get it started. I've had it checked at several places and no one can find the problem. Not even the dealer. The pump comes on but there is no pressure in the injector lines.If anyone can help l would be appreciate it. I've been trying to get this fixed for over a year.
I had a Cadillac under warrantee & had to tell the
dealer what to do,so you know my feelings about them
I suspect the fuel pump failed
The pump running doesn't tell you anything
A pressure gauge on the shrader valve, on the
engine will be a good start & you could drive it
with the gauge taped to the windshield
So all these shops & a dealer,just told you to go home
they don't care? Sadly I know the routine
No you have to make sure your just looking for fuel &
not a bad crank sensor etc. If you get no crank signal
the fuel pump will time out after 10 seconds or whatever
You have to find the right shop,apparently not an easy
feat in your area.
Some vehicles need an oil pressure switch to actuate
the fuel pump
I am just throwing out generic suggestions here,not nec
your cars systems
Jul 01, 2011 | 1995 Cadillac DeVille
186 people viewed this tip
David Payne
David Payne
