Tip & How-To about Computers & Internet
Connect A Psx Pad To Pc, Warning soldering is involved..
If you are feeling adventurous ...
If you have a PlayStation and a PC, and do not have a pad for the Computer, or simply those that there are in the market seem to you too expensive or any you don't like, you have a great option here. It connects your PlayStation pad (anyone) to your PC conserving ALL its functionality thanks to the excellent driver DirectPad.
Advantages
It enjoys the ample range of pads that exists mainly for PlayStation and, of its compared price those of PC (speaking in terms quality - price).
They work for all pads including the dual - shock pads. Also, with the dual -shock ones you will be able to use both analog controls and the capacity for "vibrating" (Force Feedback) in Windows games that support it (Need Speed III, Incoming, Star Wars Rouge Squadron, Flight Simulator, Forsaken, etc). If you want to see the complete list of games that support the Force Feedback, look here.
You will be able to use ALL the buttons of PlayStation pad in your preferred games, altogether 10 if you see digitals or 16 of you use the analog control.
You can connect simultaneously up to two pads.
With the dual - shock pads you will be able to change between the digital control to analog during any game session.
If you already have standard PC pad you will be able to use it simultaneously without losing functionality in either of them (if connecting two joystick/pads by a Y connector and to the game port, you will only be able to use 2 buttons in each joystick/pad)
The assembly is not very complicated.
In theory it would have to work with any control system of game for PlayStation (pad of another mark, steering wheel, etc).
Disadvantages
You will only be able to use it in windows games, since driver it is programmed for DirectX.
If you want to use the dual - shock you will need an external power supply, or steal power from inside the computer.
The connection goes to the parallel port, which means that if you are going to use the printer you change connectors... but it is worth the trouble!
Words before beginning
Following with the preliminaries, I will going to make clear that you do not need any knowledge electronics, although knowing how to solder and know how to handle a multi - meter. If you do not have any idea, or don't want to do it get a friend who knows to help you.
Computers & Internet Logo
My PS3 controller won't go to the right. Help!
The problem could be as simple as a loose connection .. Control pads are fiddly and can get very frustrating I ended up buying a new pad as I figured that the stress wasn't worth the cost of a new 1 but 1 of my pads used to pull to the right constantly and the problem was solved by taking the pad apart and simply cleaning the inside and making sure all wires was connected .. Sorry I couldn't be more help
Aug 25, 2012 | PDP Afterglow AP.2 Wireless Controller for...
my laptop always overheats,, its prevelant most with videos and internet explorer so i have to use google chrome. is there a way to correct this?
First, you'll want to make sure your computer is in a well-ventilated area. If your vents are blocked, none of the hot air can escape your computer and that'll lead to overheating. If the vents are clear, they might be clogged from dust on the inside. If you're feeling adventurous you can open the computer and dust it out with some compressed air, but don't do that if you're afraid of breaking something. You can also buy an external cooling pad to set your computer on, and that'll help circulate the air under it better.
Apr 12, 2011 | HEWLETT-PACKARD Compaq Presario CQ61412NR...
How to uninstall a 1998 version of Land Before Time Math Adventur
Have you tried the uninstall procedure available with Control Panel ?
If not, do you need help with that ?
Click
Start, Control Panel, locate and highlight "The Land Before Time" program by clicking it, then click uninstall.
Jun 04, 2009 | Sound Source Interactive The Land Before...
130 people viewed this tip
David Payne
David Payne
