Tip & How-To about Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno VX2 Radar heading alignment
Please take the time to rate this tip!
This tip applies to all VX2 radars from Furuno. Models Include 1724c, 1734c, 1824c, 1834c, 1934c, 1944c, 1954c, 1964c, 1724cnt, 17234cnt, 1824cnt, 1834cnt, 1934cnt, 1944cnt, 1954cnt, 1964cnt, and 19XXBB series black box radar processors.When the picture is "crooked", "rotated" or "needs re aiming" you need to do the radar heading alignment. In order to do the radar heading aligment, you must access the installation menus, available only in installation setup mode.
Press and hold "MENU" during power on.Continue holding menu during start up, at least until the boat appears.
Choose , "Installation Mode", Choose "Menu", "System Configuration", "Installation Set Up" "Radar Set Up".
Here is where people get lost! Choose "Next Page", Choose "Heading Alignment". You will be prompted to place the dotted line on a target "dead ahead". Follow instructions and then, do not forget to press "SET". Press Return Return Return or Menu to exit and resume normal operation.
Note that the installation menus disappear if they are not accessed for five minutes!.
Please take the time to rate this tip.
That is all there is to it.
Please "Optimize Radar Video" in same menu (Radar Set Up).
847-746-0100
www.technicalmarine.com
Furuno Navnet 1834C/NT vx2 Radar C Map Nt Logo
Radar on 1734C does not have heading information
Maybe your compass is dead.
did it ever work?
JB 847-746-0100
Sep 17, 2012 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
My 1734c will not boot past the black disclaimer
You will have to get a software update and have someone reflash the unit or perform factory reset by holding down the alarm button when pressing the power button.
May 15, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
This is a bit of bummer. Usually (and I hope in your case too) it is just a software problem. As a navnet is basically a computer this can happen. First I suggest you unplug everything except power and start it up, just to see if something on the network port isn't messing it around. If it still gets stuck take it to your local Radio Holland office or another furuno certified service outlet to reload the software.
Mar 27, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
3,248 people viewed this tip
Top Furuno Boating Experts
Daniel Dollive
Daniel Dollive
Colin Stickland
Colin Stickland
Shehu Pro
Shehu Pro
Are you a Furuno Boating Expert? Answer questions, earn points and help others
