Tip & How-To about Heating & Cooling
Steam System Steam Radiator Air
If you have a steam heating system you know how great the heating is from that type of system. You also know that there are not many people left that have a quality knowledge of what it takes to trouble shoot these systems.
One of the most common problems is getting the air out of the radiators effectively so that the steam can replace the air and make heat for your home. This steam flow needs to be properly controlled. If too much steam flows through it is wasted and efficiency drops. If not enough steam is supplied then the radiator will not heat to it’s fullest capacity.
If you have a one pipe system then you will have a vent on the side of the radiator near the top. The job of this vent is to release the air out of the radiator till it is full of steam. Once the heat from the steam hits this valve it will then close until it cools enough to allow more steam in the radiator again. If this valve does not do this properly then you will either loose steam out of the vent, and make a mess from the condensation or you will not get the air out of the radiator and you will not get enough heat. These valves also can be sized to allow more of less air out depending on the size of the radiator and the distance from the boiler.
If you have a two pipe steam system then you will have a trap on the return pipe of the radiator. This trap is on the side opposite of the valve. The top of the trap is screwed tightly on and can be removed with a pipe wrench. It is advisable to use two wrenches so that you do not break the piping when turning on the top of the trap. Inside the trap you will find a disc that has a thermostat in it. This disc snaps open and shut as the stem heats it up and it cools down. These discs are specific to each brand and size of trap. For proper operation of the trap you will need to match the replacement to the specific make and model of your trap.
Most of the time when you have a heating problem with one of you radiators, the trap or venting will be the problem. Very seldom does a pipe become clogged or there is some other problem that causes you not to have heat in one radiator.
http://www.fixya.com/support/r4008078-differences_between_steam_hot_water
http://www.fixya.com/support/r4001015-bleed_radiator
Heating & Cooling Logo
have aqua lazer mop steam not coming out very well
I had the same problem After removing the cleaning head, I found that putting half a cup of white vinegar into the water container (straight) and turning it on, letting the pump take the vinegar to the steamer.
A little bit of spitting and tooting followed by the smell of vinegar in the small amount of steam that was coming through let me know that it had permeated the works.( the heating element).
Turning the appliance off overnight, I finished the cleanup job the following morning using a long pin to insert into the steam outlet nozzle to loosen any debris...BEFORE TURNING IT ON...WARNING...BEFORE TURNING IT ON...Steam burns are not pleasant.
A little more Vinegar in the container and int roared back into life, I let it run for a while whilst it spat out the accumulated debris. I then flushed the system with a fresh container of water and I\'m proud to say that, after replacing the cleaning head, it now works like a charm.
Lesson: Regular use of white vinegar through the system should prevent lime scale, or other buildup, and prevent any further problems that could lead to a heating element meltdown.
Aug 05, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hi, I have been given a Euro-Pro Ironing Solution EP1005 without a manual where do I put water in for steam & how does the suction work Marj
I don't know that system, but you're real lucky, that type of irons are fantastic! Most such have something that looks like a big black knob (you can see the same type e.g. on steam cleaners). You screw it counter-clockwise until it opens. Then you fill it up with water through the little hole. That type of valve is the one I have seen the most on pro systems, while my own home type generator iron only has a tank you simply pull off so you can fill it under the faucet. I have no idea how the suction works, except for it being real great as it helps draw the steam through the garment and away, so it gets dry instantly. I'm sure it also allows you to use a lot more steam, e.g. on tough wrinkles...
Why don't you go to the Euro-Pro website, mail them and ask for their help in getting a manual for it? Or maybe you already tried that? If you look around, you might be able to get a downloadable manual from one of the many manual sellers online...
Oct 27, 2009 | Euro-Pro EP1005 Iron
564 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
