Tip & How-To about Office Equipment & Supplies
8400/8500/8550/8560/8860/C2424/8560MFP/8860MFP Homing the process gear
Hey guys this is a video tutorial that shows you step by step how to fix the error codes, on the machines that are on the title. Some of these errors are:
  • 7,007.49: The process motor stalled while tilting the head
  • 7,008.41-43: The head tilt is not engaged, or the printhead is stuck in the tilt position by the tilt arms.
  • 7,009.42: The printhead is tilted back but not properly restrained in the park arms.
  • 7,010.43: The printhead is stuck in the tilted position, or is not tilting properly over the CAM, due to problems with the process motor gearbox.
  • C3T Strip flag time-out during transfix.
http://www.youtube.com/watch?v=oGKg-HLXGpA
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
ps2 - guitar hero world tour not working
Hey guys!!!!!!Guitar hero world tour is a dual layer disc and same as some gods of war disc etc. Older ps2's only player single layer discs!!!!You would have to upgrade take it in & get fixed or buy a new ps2!!!!!!Hope this helps U guys take care FT....
Dec 29, 2008 | Sony PlayStation 2 Slimline Console
E74
The E-74 error is also due to overheating and the RROD fix also cures this fault, hope that helps :)
Nov 11, 2008 | Microsoft Xbox 360 Console
error code 0102
If you're comfortable enough opening your 360, you can try this tutorial, which has worked for many people.
Jan 07, 2008 | Microsoft Xbox 360 Console
1,496 people viewed this tip
k24674
jasbo
jasbo
