Tip & How-To about Apple iPod nano
How to restore iPod Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer. Download and install the latest version of iTunes if you do not already have it installed. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod. After a few moments, your iPod will appear in the Source panel in iTunes. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are: Restore Option 1: Restore - Restores with same iPod Software version already on iPod. Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available. Restore Option 3: Use Newest Version - Restores with the latest iPod Software available. Restore Option 4: Restore and Update - Restores with the latest iPod Software available. If you are using a Mac, a message will appear prompting you to enter an administrator?s name and password. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring. Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models). Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models). During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Apple iPod nano Logo
how do i reset ipod nano 2G, I am getting nothing
To restore your I-pod, do this:
1) Ensure that you have an active Internet connection as new versions of iTunes and iPod Software
2) Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that
3) Select your iPod in the Source panel and you will see information about your iPod appear in the
4) Click the Restore button. You will be prompted with one or more restore options that may prompt
iTunes to automatically download the latest iPod Software. Use restore option 4.
Apr 14, 2010 | Apple iPod nano
how do i restor my ipod?
Ipod restore
In these instructions (from the apple website), there is an option that does not require the internet.
How to restore iPod
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2 (tsegamamo8 , use this option, and the internet should not be required): Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Nov 28, 2008 | Apple iPod classic MP3 Player
Changed computers
I'm making an assumption that iTunes was working before on the other computer, and now that you have switched computers, the Nano is not being recognized by iTunes?
Try this, from Apple's website:
http://support.apple.com/kb/HT1339
Summary Learn how to restore iPod, iPod classic, iPod mini, and iPod nano to factory settings.
If you need to restore an iPod shuffle, click here.
Background It is important to understand the difference between "update" and "restore". Update simply installs the software that controls iPod and does not affect the songs and files stored on iPod's disk. Restore erases the iPod's disk and restores iPod to its original factory condition.
Warning: because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library. If you use the Nike + iPod Sport Kit, see this document for more information.
Products Affected iPod, iPod mini, iPod nano, iPod classic
How to restore iPod
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Jun 25, 2008 | Apple iPod nano
ipod shuffle
You should do a restore:
How to restore iPod shuffle
  3. Open iTunes, and then connect iPod shuffle to your computer.
  4. After a few moments, it will appear in the Source pane in iTunes.
  5. Select your iPod shuffle in the Source pane and you will see information about it appear in the Settings tab of the main iTunes windows
  6. The Version section tells you whether iPod shuffle is up to date or needs a newer version of the software.
  7. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
  8. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  9. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present a message instructing you to leave iPod shuffle connected to computer to complete restore process.
  10. During the stage 2 of the restore process, a green LED will flash once on iPod shuffle, then amber and green LEDs will flash briefly, and finally the amber LED will begin to flash continuously. It is critical that the iPod shuffle remains connected to the computer during this stage.
  11. After stage 2 of the restore process is complete, the iPod Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Dec 29, 2007 | Apple iPod shuffle MP3 Player
1,052 people viewed this tip
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
